Pocket GPS World :: View topic - Permantly powered up Fortuna
etch
PostPosted: Fri May 28, 2004 9:49 am    Post subject: Permantly powered up Fortuna Reply with quote
Newbie here. I am thinking of getting Ipaq H4150 with Fortuna: 'Clip-On' Bluetooth GPS receiver (SiRF Xtrac chip) and TTN3.
my question is is it OK to leave the Fortuna permantly powered up? I have a 12V socket in the boot of the car where I want to plug it in to keep the dash clear, but it is permantly on (even when ignition off).
Roger
lbendlin
PostPosted: Fri May 28, 2004 6:30 pm    Post subject: Reply with quote
Technically it is not a problem, but you may consider the following
- your car battery may drain if you leave your car unattended for a longer time (eg. unplug then fortuna in these cases)
- the battery in the Fortuna may get de-calibrated after a while. Make sure you completely discharge it from time to time (use it outside the car)
Lutz
TomTom/TeleAtlas NAVTEQ
BigH
PostPosted: Mon May 31, 2004 5:19 pm    Post subject: Reply with quote
I have already done this, I have removed the battery and left the device permanently powered for about two months now without problems. Current consumption (battery removed) is about 90 mA. Unless you have a poor car battery or leave your car for months then you should be fine.
The really nice thing is no TTFF waiting!!
Regards BigH
cpmdoc
PostPosted: Wed Aug 04, 2004 7:30 pm    Post subject: Permanently powered up Fortuna! Reply with quote
Here's a thought:
If you can leave the Fortuna on for long periods and without the battery installed...then if your car was stolen could the GPS unit be traced? Question
I know that there are websites that do a similar thing for GSM phones e.g.:
www.followus.co.uk
Having just had my car replaced after my old (11 months!) one was stolen then it would be nice to know that this oculd be done by the police - rather than installing an expensive tracking device!
Chris
Dell Axim X5, Fortuna Clip On, TTN3
lbendlin
PostPosted: Wed Aug 04, 2004 7:42 pm    Post subject: Reply with quote
The GPS unit can't be traced, it is a purely passive receiver. What you need is an active connection somewhere (for example a GSM sender). Some of the higher priced GPS receivers actually do have that, and some of the children's mobile phones come with a built in GPS receiver - same effect. So for example you can send a SMS to the phone asking for the position and would get a SMS back with the data provided by the GPS receiver.
What you do need in any case is a dumb thief/suspect (like this Scott Peterson in the US who didn't notice that the FBI had bugged his car with a GPS logger). Smart bad guys have figured this out long time ago and will not allow tracking/logging to happen. All you need to make the GPS receiver useless is to take the sky view away (remove the antenna, put some metal cover over it etc)
Lutz
22.064 (26 Jun 24)
