Andy_P Pocket GPS Moderator
Posted: Wed Sep 03, 2008 3:38 pm Post subject: |
If you connect the Go to the PC, can Windows recognise it as a new disk drive? |
Simon1969 Occasional Visitor
Oldboy Pocket GPS Moderator
Posted: Thu Sep 04, 2008 3:52 pm Post subject: |
This one would be better.
It's faster, cheaper and bigger.
I had the identical card in a GO Classsic and it's still in use today.
2GB means that you should never get the message that 'there is not enough room'. _________________ Richard
Posted: Thu Sep 04, 2008 4:46 pm Post subject: |
Hi Oldboy, ta for your reply.
Card price looks great.
My Go 300 is over 3 years old though, do you think the in built card reader will be sophisticated enough to recognise the new SD card? |
Posted: Thu Sep 04, 2008 5:32 pm Post subject: |
A 2GB card will be fine in the older devices, it is 4GB and above that would be problematic as they tend to SDHC rather than plain SD - Mike |
Posted: Thu Sep 04, 2008 6:10 pm Post subject: |
Simon1969 wrote: | My Go 300 is over 3 years old though, do you think the in built card reader will be sophisticated enough to recognise the new SD card? | The Classic GO is now over 4 years old and still going strong. _________________ Richard
Posted: Mon Sep 08, 2008 4:33 pm Post subject: |
Oldboy wrote: | This one would be better.
2GB means that you should never get the message that 'there is not enough room'. |
My 2gig card arrived today. However, without a card reader how can I transfer the data from the backup on my PC to the new card?
When I turn on my tomtom with the new card in and connected to my PC, nothing happens. ie the screen doesnt come on and the device is not seen in explorer.
Does this mean I cant upgrade to the latest version nor download any maps without an SD Card Reader? |
philpugh Lifetime Member
Joined: Dec 28, 2005 Posts: 2003 Location: Antrobus, Cheshire
Posted: Mon Sep 08, 2008 5:20 pm Post subject: |
I would seriously consider investing in a card reader - they are inexpensive and considerably faster and easier to use than cards via satnavs / PDAs etc. My last one - it claims to be a "21-in-1" reader which it may be - but it has 4 slots, was obtained for £5 on top of an order for my 4Gb card for my camera.
If your TT unit relies on the card being in to run then this would be the only alternative. _________________ Phil |
Posted: Mon Sep 08, 2008 5:43 pm Post subject: |
Simon1969 wrote: | When I turn on my tomtom with the new card in and connected to my PC, nothing happens. ie the screen doesnt come on and the device is not seen in explorer. |
When you put a new card in you should still see something on the screen. Even if it's telling you to take the card out.
Try a Reset, and see if it then starts up. If it does, and tells you to take the card out, connect it to the PC and see if it's there now. _________________ Richard
Posted: Mon Sep 08, 2008 5:45 pm Post subject: |
philpugh wrote: |
If your TT unit relies on the card being in to run then this would be the only alternative. |
A slightly misleading reply that...
Simon.. your Go SHOULD work as a card reader itself when the new card is inserted.
Obviously it won't work as a sat-nav with the raw card in it but Windows SHOULD recognise it as a new hard drive and let you copy and paste files to and from it just like any other drive.
So we need to work out why it isn't....
TomTom have a quite good page for the three main connection to PC problems HERE. Number 1 or 3 should give you some pointers.
If you put the original card in, does windows recognise it then?
When you connect the USB cable and switch on the Go it's screen should say "Do you want to connect to 'computer' ".
It should also do the same thing with the new card. |
Posted: Tue Sep 09, 2008 11:02 am Post subject: |
Andy_P I agree my reply could be misleading - but Simon1969 had already stated that he can't see the new card when inserted into the TT unit. _________________ Phil |
Posted: Tue Sep 09, 2008 8:36 pm Post subject: |
mikealder wrote: | You can select either the UK&ROI map for £29:95, or go for the Western Europe Map at £49:95 both these prices are currently discounted by £10, you will probably need a new (larger card) to get either map to fit along with the application, postcodes and voices. The latest map release you can use is the v720 map - Mike |
Many thanks for your replies. I've now managed to reset my device and install the new SD card, onto which I've copied my tomtom backup and updated the software.
At the moment I can connect to tomtom home but cant create an account as the site is down so will delay upgrading my maps.
However the latest Great Britain map is quoted as version 725 at £39.95.
Mike, is this the only source for this map as its double the price that you kindly quoted above? |
falkirk81 Pocket GPS Verifier
Joined: Jul 07, 2006 Posts: 1649 Location: Newcastle, England, UK
Posted: Tue Sep 09, 2008 8:40 pm Post subject: |
Yes 39.95 is the current price for the v725 map. the v810 map for x20 and x30 devices is 49.95.
The new maps can only be bought directly from tomtom, either through the website or via tomtom home. Either way, you will need tomtom home to install the map to your device! _________________ Tomtom GO 1005 LIVE
iPhone 12 |
Posted: Tue Sep 09, 2008 8:54 pm Post subject: |
When I posted the above information it was correct:
mikealder wrote: | You can select either the UK&ROI map for £29:95, or go for the Western Europe Map at £49:95 both these prices are currently discounted by £10, you will probably need a new (larger card) to get either map to fit along with the application....... |
The maps were available for a period at a discounted price, now the new release maps are available they are at full price.
There is no alternative to purchasing and downloading the maps from TomTom for your device the v725 map is the very latest (less than a week old) for your device - Mike |
Anita Pocket GPS Moderator
Joined: Mar 15, 2006 Posts: 3219 Location: Windlesham, Surrey
Posted: Tue Sep 09, 2008 9:10 pm Post subject: |
Simon1969 wrote: | mikealder wrote: | You can select either the UK&ROI map for £29:95, or go for the Western Europe Map at £49:95 both these prices are currently discounted by £10 . . . |
. . . However the latest Great Britain map is quoted as version 725 at £39.95.
Hardly double the price.
Mike said the price of £29.95 he quoted was discounted by £10, so one would expect a newly released map to be at least £39.95 - the same as the full price of the previous version. _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21 |
