Pocket GPS World :: View topic - How do I activate & register a pre-programmed data card
mrzipy
PostPosted: Sat Sep 06, 2008 2:20 pm    Post subject: How do I activate & register a pre-programmed data card Reply with quote
I am new to Garmin, from TomTom
Anyway I purchased an NT map on a pre-programmed data card.
Questions I have, which are not answered on Garmins site.
1. Do I need to activate this card, or does it just work?
2. Where is the map serial number so I can register it?
Sorry if these are silly questions.
Thanks.
mrzipy
PostPosted: Sun Sep 07, 2008 3:32 pm    Post subject: Reply with quote
No-one here ever purchased a preprogrammed data card?
PhilHornby
PostPosted: Sun Sep 07, 2008 8:06 pm    Post subject: Re: How do I activate & register a pre-programmed data c Reply with quote
Not me - but I won't let a lack of knowledge stop me answering your questions Very Happy
AIUI, it should just work. Doesn't it?
The map doesn't have a serial number. I'm not sure there's any point registering it (even if Garmin's website will let you). I don't think you can officially upgrade an SD card product in the future (even though technically it might be possible). That would be about the only advantage in registering.
I reckon your card contains two files: GMAPSUPP.IMG and GMAPSUPP.UNL. Is this correct?
The GMAPSUPP.IMG will contain exactly the same contents as a GMAPPROM.IMG on a unit that came with the same map pre-installed. GMAPSUPP.UNL will contain the unlock code for the device that the maps are licenced to. In the case of a pre-programmed card, this is the Serial Number of the SD card. (Garmin don't use any of the fancier SD features, just the serial number). You can see the Serial Number of the card, in the SD card diagnostics page. You could try sticking that number in the Garmin website and see what sort of error message you get Confused
If this SD card is a later version of a pre-installed map, you probably want to disable the earlier version. Go to 'tools' | Map | Map Info (exact location varies by device) - and un-tick the earlier one.
mrzipy
PostPosted: Mon Sep 08, 2008 12:49 pm    Post subject: Reply with quote
Thanks for the reply, didn't think anyone was alive in the forum!
It does appear to just work, I used the simulator mode and set my location to a place in the US (I am in UK) and simulated a route, I'm used to TomTom where you can to an A-B route to test.
I asked about a serial as the Garmin site allows you to register your maps from a pre-programmed data card - thought i was missing a serial.
"Preprogrammed Data Card Serial Number
(Example MUS001R) "
Could not find anything to do with SD card on diagnostics screens.
Thanks though.
nubi
PostPosted: Sat Apr 18, 2009 4:58 pm    Post subject: You don't need to enter that "serial number" Reply with quote
You can leave it blank. I think it is there in case the product you are registering is a map that is not listed in the menu above; in that case, you can type in the "M" number. It's more like a model number than a serial number.
22.055 (29 May 24)
