Pocket GPS World :: View topic - camera sounds in tom tom XL
akion
PostPosted: Sat Sep 06, 2008 8:24 am    Post subject: camera sounds in tom tom XL Reply with quote
I have loaded the pgps world camera files and the ogg sound files onto my new XL but although the cameras show the sounds do not work or even appear when setting up poi sounds Sad
Has anyone a solution to this please ?
Thanks Akion.
PostPosted: Sat Sep 06, 2008 8:45 am    Post subject: Reply with quote
You need to ensure you have downloaded the correct voice alert set that matches your database type i.e. Consolidated/Speed Zoned etc. You must also check that you correctly unzipped the files and copied them into the correct map folder.
If you look in your map folder (and assuming your speed camera database is otherwise working correctly) you should have three files for each camera, the database file, its accompanying icon file and the alert file e.g.:
pocketgps_gatso_30.ov2 (database)
pocketgps_gatso_30.ogg (sound)
akion
PostPosted: Sat Sep 06, 2008 9:26 am    Post subject: camera sounds in tom tom XL Reply with quote
Many Thanks Darren for prompt reply problem was incorrect sound file !!
Now working just great just need to set up each camera ( no problem)
Many thanks keep up the good work
Regards Akion
22.063 (19 Jun 24)
