Pocket GPS World :: View topic - UK verses Europe
UK verses Europe
busterg1955
PostPosted: Fri Sep 05, 2008 6:18 pm    Post subject: UK verses Europe Reply with quote
UK verses Europe
I have a tomtom 720. Due to any possible memory limitation, can any one say if the detail and information given on the UK map is greater then that shown in the Europe map?
Robin2
PostPosted: Fri Sep 05, 2008 7:18 pm    Post subject: Reply with quote
Generally the roads are the same, but as the larger Europe maps are compressed to fit onto a smaller card, bends in the road are broken down into fewer segments so may look a little more jagged on the screen. Also, there is much less extraneous detail - woodland, expanses of water, etc - on the compressed maps. But from the routing point of view, they are pretty much the same
Robin
TomTom One v3 Europe, Navcore 7.903, Western Europe 835.2420
Satmap Active 10
Plus a lot of other PDA GPS kit, seldom used
uffe73
PostPosted: Fri Sep 05, 2008 7:38 pm    Post subject: Reply with quote
Robin
Are you sure about this? Does the regional maps really contain more map details than the Western Europe map? I haven't noticed this difference, but I haven't examined it carefully either...
Trevor1234
PostPosted: Fri Sep 05, 2008 8:16 pm    Post subject: Reply with quote
I must admit that I cannot see any difference. If there is a difference I'm sure that it will neither be noticeable or affect the driver.
Tomtom Go 720.
Navcore 9.510
Central and Western Europe v855.2884
GPS World Traffic cameras
Home 2.7
iPhone 3G
Robin2
PostPosted: Fri Sep 05, 2008 8:50 pm    Post subject: Reply with quote
The difference is noticeable on the 1GB Europe maps, but less so on the maps which take up almost 2GB. But from the routing point of view they are almost identical
Robin
Satmap Active 10
PostPosted: Fri Sep 05, 2008 9:27 pm    Post subject: Reply with quote
There are different "cuts" of the map data to cater for the different devices with the fixed internal flash memory, not all devices have the option of the external SD card slot for larger maps. These 1GB maps often do have certain non essential detail reduced or removed, in use you still get routed from AtoB down the same roads (IQ Routes excepted - as these map files are larger containing more detail and data). - Mike
22.071 (03 Jul 24)
