Pocket GPS World :: View topic - What is the difference between backups on home,and explorer
joeann90
PostPosted: Sat Aug 30, 2008 12:46 pm    Post subject: What is the difference between backups on home,and explorer Reply with quote
HI, Smile
I was wondering what is the difference between backing up your tomtom sat nav on windows explorer,and on tomtom homes web site,it looks very complicated to back up with the explorer method Confused as i am new to this,and want to make sure i do it correctly Very Happy on the home software it looks far easier, is one method safer or better Confused can anyone explain Very Happy thanks for any advice. Smile Smile
PostPosted: Sat Aug 30, 2008 12:59 pm    Post subject: Reply with quote
The Home Backup has had issues for some considerable time, with the 910 devices it made the Text To Speech system fail to work as it re-named most of the files within a folder, it also only allows a single backup to be taken, each subsequent backup will overwrite the previous one which is not good. It does work, but users have grown to mistrust Home.
Most of the forum users use Windows Explorer for backups, it is easy to do, should you need any guidance for this have a look at the FAQ page #1 by clicking Here - Mike
Oldboy
PostPosted: Sat Aug 30, 2008 1:14 pm    Post subject: Re: What is the difference between backups on home,and explo Reply with quote
joeann90 wrote:
I was wondering what is the difference between ...... backing up your tomtom sat nav on windows explorer,
Peace of mind. Smile
joeann90 wrote:
..... and on tomtom homes web site,:
A nagging fear that it might not be complete. Sad
dhn
PostPosted: Sat Aug 30, 2008 1:15 pm    Post subject: Reply with quote
A couple of issues using Home to do backups. First, whenever you backup using Home, it overwrites the previous backup made rather than creating a backup in a differently named folder. It's often better to have more than 1 backup set and overwriting defeats that purpose.
The second issue is that some users have observed that some files that should get backed up in fact get missed in the process.
Having said the above, be clear that for some, using just Home to do the backup doesn't seem to be an issue. As ou've observed, though, most here strongly suggest using Windows Explorer to do the job. It isn't hard and is much safer.
Here are the steps. First of all, in its 'wisdom', Windows hides certain files by default. They are there but aren't able to be seen. The problem is that backup utilities sometimes miss these hidden files. So, we want to make them visible. Go into Control Panel. Folder Options. View tab. In the Advanced window settings, check 'show hidden files and folders'. While you are at it, uncheck the next line 'hide extensions for known file types'. In otherwords, we DON'T want them hidden. Check 'apply' and close Control Panel.
Open Windows Explorer. Highlight 'My Computer' and highlight Local Disk (usually C:\) In the top menu, File--New--Folder and give it a meaningful name like 'TT backup 8/31'. You should also see another disk showing that represents the tomtom unit. You probably see the tt logo. Highlight it and in the right panel, all the folders and files of the unit are shown. Simply do a Ctl-A (Control-A) which highlights everything. Now, right click and select copy. Now, left click on your new folder you made, right click and select the paste option. Wait a few minutes and that is it! You are done.
Trevor1234
PostPosted: Sat Aug 30, 2008 1:28 pm    Post subject: Reply with quote
Hi joeann90
Both Mike and Oldboy have given you the answers and for me the fact that ‘Home’ overwrites the previous back-up makes me steer clear of ‘Home’.
With the Windows back-up one can make back-ups as and when necessary. I have a back-up made when the device was new, one made just before and after installing the new map 720 and one made before installing Navcore 8. That means that I can go back to any point that I choose in the safe knowledge that everything will turn out all right.
Its easy to keep backups on DVDs, hard drives or other hardware.
Tomtom Go 720.
Navcore 9.510
Central and Western Europe v855.2884
GPS World Traffic cameras
Home 2.7
iPhone 3G
joeann90
PostPosted: Sat Aug 30, 2008 2:49 pm    Post subject: Reply with quote
Smile Thanks for advice,
sorry to sound stupid ,but i take it i have to have sat nav connected by usb Confused and switched on as well, then open windows explorer and do as you say, Smile
PostPosted: Sat Aug 30, 2008 3:10 pm    Post subject: Reply with quote
This is correct, if TomTom Home starts up on the PC just exit the application or minimise it so it doesn't get in the way - Mike
Calomax
PostPosted: Sun Aug 31, 2008 2:56 pm    Post subject: Reply with quote
One more disadvantage of using HOME is I think it can't then copy a backup to DVD which is highly recommended. At least you should have a backup out of the box or as early as possible.
TT Go Essential
22.064 (26 Jun 24)
