Pocket GPS World :: View topic - conflict with poi's & speed camera icons
Dunch
PostPosted: Wed Aug 27, 2008 11:04 am    Post subject: conflict with poi's & speed camera icons Reply with quote
I can install speed cameras no problem (from pgps site)& they display the appropriate icons however as soon as i install poi's from the pocket gps database the camera icons show up only as grey dots. The other poi's display as normal, It appears I can have one or the other but not both together as this is when the problem arises - does anyone know what the problem is?
I'm using a Nuvi 350 with the latest firmware & the updated poi loader
Thanks Confused
PostPosted: Wed Aug 27, 2008 11:18 am    Post subject: Reply with quote
hi,
it sounds as though you may have an extra ".gpi" file on your device. if you connect your device to the computer and look at the contents can you tell us what .gpi files there are in the 'Garmin' folder?
also, ALL poi's must be loaded at the same time - as soon as you upload any more it first removes the current poi.gpi file.
PostPosted: Wed Aug 27, 2008 11:20 am    Post subject: Reply with quote
having said that, i notice you have been using both ash10's "camera manager" software as well as downloading the files manually - you only need to do one or the other. the icons may be an issue with camera manager?
Dunch
PostPosted: Wed Aug 27, 2008 1:21 pm    Post subject: Reply with quote
there are 2 .gpi files in the folder - 1. poi.gpi & 2. gpg.gpi (good pub guide).
I have only recently installed the good pub guide but I had the grey dots problem before then.
I thought i'd cured the problem last night by clearing out all my poi's & installing the cameras only with ash's program - the speed camera icons displayed no probs, however as soon as i added the other poi's into the folder & uploaded everything together the result is the camera icons only display as grey dots.
I have even gone into diagnostic mode on the unit & cleared out waypoints etc without any effect.
Thanks for your swift response & help so far Smile
Dunch
PostPosted: Wed Aug 27, 2008 2:04 pm    Post subject: Reply with quote
a brief update - installed cameras & poi's manually instead of using ash's camera manager with the same result !!
PostPosted: Wed Aug 27, 2008 7:49 pm    Post subject: Reply with quote
do any of your POI files have under scores _ in their names? this seems to have caused an issue with similar effects...
it didn't use to but i wonder if this new feature has been added with a firmware upgrade? if so then we may have problems with the pgpsw database... Mad
Dunch
PostPosted: Wed Aug 27, 2008 11:43 pm    Post subject: Reply with quote
have checked the poi files & almost all of them have under scores in their names including the speed camera files.
eg 1. Alliance_&_Leicester_ATM.bmp & Alliance_&_Leicester_ATM.csv
eg 2. pocketgps_uk_mobile.bmp & pocketgps_uk_mobile.csv
hope this helps to solve the problem Smile
Thanks MaFt
PostPosted: Thu Aug 28, 2008 10:45 am    Post subject: Reply with quote
are they installed on the device itself or onto a memory card?
Dunch
PostPosted: Thu Aug 28, 2008 11:34 am    Post subject: Reply with quote
all poi's are being installed onto the unit itself via garmin poi loader software
PostPosted: Thu Aug 28, 2008 1:43 pm    Post subject: Reply with quote
i'm lost then... Question
sorry!!
Dunch
PostPosted: Thu Aug 28, 2008 8:30 pm    Post subject: Reply with quote
haven't got time at the mo but I'll load some poi's from other sources & see if I have the same problems.
In the meantime thanks for your efforts.
Cheeors Cheers!
GerryC
PostPosted: Thu Aug 28, 2008 8:37 pm    Post subject: Reply with quote
MaFt, Don't have a clue about this but Wed 11:18 you asked about having extra gpi files and Dunce replied at 1:21 saying he had 2.
Also, I remember something about grey dots when using the single file version on Nuvis when we were looking at the M42 cameras though that was a side issue.
I don't know if either of these have any bearing on the issue.
Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount
PostPosted: Fri Aug 29, 2008 3:17 pm    Post subject: Reply with quote
the 2 files he has though are different names. the issue with 2 .gpi files was that both files actually (somehow!) had exactly the same file name.
you can use multiple gpi files on the garmin and we even recommend this in terms of installing a uk and eur database onto the units.
the single file issue was, if i remember correctly, actually caused by having the 2x poi.gpi files?
PaulB2005
PostPosted: Fri Oct 17, 2008 9:28 pm    Post subject: Reply with quote
Has this been resolved? if not, how many POI categories are you loading in total?
marksnsparks
PostPosted: Sun Oct 19, 2008 5:36 pm    Post subject: Reply with quote
I think the dot appears if you have too many points of interest categories loaded. Try deleting the points of interest and just loading the camera database files using poi loader. All should be well. If you want the other points of interest just keep the number of categories to a reasonable amount. I think it revolves around 257 categories as the limit, although I'm not entirely sure.
Garmin Nuvi 310 - Version 4.70 Firmware.
V9 Maps
Audio version 2.30
GTM12 - Version 4.80 Firmware
GPS v3.00
bluetooth software version 3.10
22.055 (29 May 24)
