Pocket GPS World :: View topic - Pin 570 & Battery
Pin 570 & Battery
phil_ossifer
PostPosted: Tue Apr 22, 2008 7:10 am    Post subject: Pin 570 & Battery Reply with quote
Can anyone tell me if it possible to change the Li-on battey in the Navman Pin 570.... if so, are there any online articles or how-to's ?
Johnerz
PostPosted: Sun May 04, 2008 12:37 pm    Post subject: Reply with quote
Lots on google Smile
look here for a start (if its simple post back I might change mine) Smile
CaptainDrift
PostPosted: Fri Aug 22, 2008 11:40 am    Post subject: Reply with quote
Is it not under warranty?
I know in some cases you can upgrade from this to the S50 or S90i with Navman
Johnerz
PostPosted: Fri Aug 21, 2009 2:43 pm    Post subject: Re: Pin 570 & Battery Reply with quote
phil_ossifer wrote:
I have just bought a new larger capacity battery from ebay This Item to be precise: title: Extended Battery for Acer N35, Navman Pin 570 1600mAh
Removing it was simple, lift the two black screw covers and remove the 4 screws, I slid my thumb nail round the joint and it popped right open, a little fiddly to remove the case, then a few more screws to lift off the circuit board, be carefull as there is a white lead to unplug to remove the board and the screen can be left attached.
Remove/unplug the old battery and all of its cover (you need the room).
Thats it all out and ready to refit.
Refitting is a bit more fiddly imho.
Plug in the battery fit it in exactly the correct position (I used photo mount spray to ensure it stayed in place but any non instant glue will do the job) then replace the board ensuring it fits correctly all around or it will bend when the screws are fitted. tighten down the screws and refit the body and the 4 screws. Almost done, if you removed the 2 black screw covers carefully then you can refit them and switch on. 15/20 minutes of your time well spend, battery life if much better Smile
23.063 (18 Jun 25)
