Pocket GPS World :: View topic - TomTom Home 2.3 / Windows Vista conflict
mickrichardson535
PostPosted: Wed Aug 20, 2008 8:42 pm    Post subject: TomTom Home 2.3 / Windows Vista conflict Reply with quote
Those running Windows Vista may have recently found (like me) that TT Home will not run. My Go 720T can still be seen and accessed by the computer, but Home refuses to start.
TomTom are aware of the issue and have no real answer - advising me that it's a Windows issue not a TomTom one.
Great.
I eventually found a way around the issue which may be of assistance to others .... here goes ....
I researched the issue on the www and found others running Vista and TTH suffering the same symptoms. Some cured it by uninstalling and reinstalling repeatedly the TTH software. I did that to no avail.
I then decided to uninstall TTH Home and clean the system of all traces of TTH (though I did not touch the registry) and then uninstall all the Microsoft / Windows / Vista updates installed since TTH stopped working.
I then reinstalled TTH (2.3) and it worked just fine.
I then reinstalled each Microsoft / Windows / Vista update one at a time, rebooting in between each update. TTH now works as it should.
The Updates affecting my machine were ...
Vista update KB651618
Vista update KB952287
Vista Security update KB953733
Vista Security update KB950974
Windows Mail update KB951066
IE7 update KB953838
junk mail update KB905866
and KB951072
Hope this helps someone.
Mick
andy-c1
PostPosted: Wed Aug 20, 2008 10:34 pm    Post subject: Reply with quote
mmmmm I must be 1 of the lucky ones then as I had no problems with vista ultimate
TomTom 5001
gardenshed
PostPosted: Wed Aug 20, 2008 11:22 pm    Post subject: Reply with quote
vista works for me too, i also have a 720t, the only issue you will have is if you try to connect with the sd card in the tt if it is over 4gb. remove it and it will connect perfectly, i have an 8gb sdhc card Wink
Eastholme
PostPosted: Wed Aug 20, 2008 11:59 pm    Post subject: Reply with quote
Had no problems with my 930T, TomTom Home and Vista. Gotta be another one of the lucky ones......
BodgerBaz
PostPosted: Thu Aug 21, 2008 7:50 am    Post subject: Reply with quote
Mine's working too with GO 510/710 and all the latest updates.
As opposed to us being the lucky ones it does seem that we are 'normal' and you are the unlucky one?
technik
PostPosted: Thu Aug 21, 2008 8:02 am    Post subject: Reply with quote
No problems here with Vista ever at all.
Everything has always worked fine.
Must be the OP's PC has corrupted files.
Hoppy
PostPosted: Thu Aug 21, 2008 8:05 am    Post subject: Reply with quote
No problems for me Vista Home Premium with TT Home 2.3 and all with latest updates.
TomTom Go 950 Live.
App 9.054
Europe v8.50
NA 2GB v8.45
turbo10
PostPosted: Thu Aug 21, 2008 8:20 am    Post subject: Reply with quote
No problems with Vista Ultimate, also with all latest updates, and my 920T
dougproctor
PostPosted: Thu Aug 21, 2008 11:58 am    Post subject: Reply with quote
Didn't even know there were problems between Vista and TTH! Works perfectly for me also.
Wazza_G
PostPosted: Thu Aug 21, 2008 4:42 pm    Post subject: Reply with quote
I run Vista HP x64 and TTH 2.3 runs perfectly.
So when are they going to issue 64-bit software then?
Kinetic
PostPosted: Thu Aug 21, 2008 6:51 pm    Post subject: Reply with quote
I can't get it to work with Vista Ultimate either.
falkirk81
PostPosted: Fri Aug 22, 2008 12:56 pm    Post subject: Reply with quote
No probs here with Vista Home and TTHome 2.3. Always worked fine for me.
Tomtom GO 1005 LIVE
iPhone 12
Mikafin
PostPosted: Fri Aug 22, 2008 4:15 pm    Post subject: Reply with quote
No problems with Vista Home Premium (all updates incl. SP1) and TT Home 2.3.1.92 (GO930T)
Smartdriver
PostPosted: Sat Aug 23, 2008 11:41 am    Post subject: Reply with quote
No problems with Vista Business with all updates and Home 2.3 either.
TT Go 6000
Previous Go 920T
Tobas
PostPosted: Mon Aug 25, 2008 4:33 am    Post subject: Reply with quote
Plenty of problems a while ago with a TTH upgrade. Like OP, had to completely remove all trace of TTH before the upgrade would run. TT were no help suggesting it was a windows problem. As usual a PGPSW forum member came to the rescue.
22.094 (25 Sep 24)
