Pocket GPS World :: View topic - Invisible speed cameras
tonyroma
PostPosted: Mon Aug 18, 2008 12:24 am    Post subject: Invisible speed cameras Reply with quote
The temporary cameras on the M5 Exeter bypass have not been there for at least 4 months but are still being downloaded, does it mean they are coming back ?
PostPosted: Mon Aug 18, 2008 7:32 am    Post subject: Reply with quote
What temporary cameras? There are no cameras on the M5 at Exeter in the database right now.
I wonder if you have an old previous copy of the database still on your device?
GPS_fan
PostPosted: Mon Aug 18, 2008 11:09 am    Post subject: Reply with quote
Having looked at the map on the submissions page, there are no temporary cameras the whole length of the M5.
There are, however, a few mobile locations, although the closest to Exeter is 18.5 miles from the southern tip of the M5 near Bradnich (MOBILE:31186@70):
Andy
tonyroma
PostPosted: Tue Aug 19, 2008 11:44 pm    Post subject: Re: Invisible speed cameras Reply with quote
OK just took off all old cam data from TT card, installed latest , and M5 is clear, must remember to erase before installing! should have noticed that these cams had 32 kb instead of 4 kb of data.
PostPosted: Wed Aug 20, 2008 12:39 am    Post subject: Re: Invisible speed cameras Reply with quote
Erasing should not be necessary IF you are installing like for like - i.e. if you download and install the speed zoned camera set every time, when you copy them into the TT, it will overwrite the existing ones. I think it's likely you used different versions previously (single file or consolidated by type), so the speed zoned didn't overwrite or vice versa, resulting in the old info staying on your TT.
22.063 (19 Jun 24)
