MaxM4XWW Occasional Visitor
Posted: Tue Aug 19, 2008 9:11 am Post subject: TT ONE, Wont turn on unless you remove and re-insert sd card |
Hi, My TT ONE has started to not turn on as if the battery is flat.
Its not flat, If you remove the SD card and re-insert it turns on.
Any ideas whats up?
Thanks |
dhn Frequent Visitor
Posted: Tue Aug 19, 2008 12:17 pm Post subject: |
Press the reset button with the card in the unit and again press the reset button with the card out of the unit. Reinsert the sd card and turn on the unit. See if that helps. |
SpikeyMikey Lifetime Member
Joined: Mar 21, 2006 Posts: 855 Location: Hertfordshire. Forever blowing bubbles
Posted: Tue Aug 19, 2008 12:51 pm Post subject: |
Hi and welcome.
This may sound stupid but a friend of mine brought his TT GO up to me the other day and said it wouldn't turn on. I pressed the button for a second or two and it fired up no problem. It turned out that he had been doing a quick press with no reponse. I'm assuming this is done to prevent accidental switch on.
Just a thought _________________ Mike
TT GO6000 (Europe); iPhone and iPad Pro with iOS TT GO & MyDrive + CamerAlert |
Posted: Tue Aug 19, 2008 4:33 pm Post subject: |
A long press does nothing, But if you take the sd card out and put it straight back in it turns on first time.
I don't really want to reset it! |
Daggers Lifetime Member
Joined: Jun 20, 2005 Posts: 1096 Location: Solihull, UK
Posted: Tue Aug 19, 2008 4:56 pm Post subject: |
Resetting it is the recommended way of re-booting the device. It does not cause you to lose any data. Press the reset button! |
Posted: Tue Aug 19, 2008 5:00 pm Post subject: |
That might of fixed it |
