Satmaniac Occasional Visitor
Posted: Mon Aug 18, 2008 3:58 pm Post subject: Ultra Skin Full Screen Mode, how? |
Anyone know how to select full screen mode on IGO8 using the Ultra 4.5 Skin?
TIA |
linknet Frequent Visitor
Posted: Mon Aug 18, 2008 5:13 pm Post subject: Re: Ultra Skin Full Screen Mode, how? |
Satmaniac wrote: | Anyone know how to select full screen mode on IGO8 using the Ultra 4.5 Skin?
TIA |
Via the "Quick Menu" in landscape mode.
linknet |
Posted: Tue Aug 19, 2008 11:11 am Post subject: |
I use my PDA in Portrait, is it only possible to do this in landscape? Then how do you access the quick menu?
Thanks for ur reply |
Posted: Tue Aug 19, 2008 11:16 am Post subject: |
Satmaniac wrote: | I use my PDA in Portrait, is it only possible to do this in landscape? Then how do you access the quick menu?
Full screen mode is only in landscape.
Quick menu is button in bottom LH corner of map screen.
linknet |
Posted: Tue Aug 19, 2008 11:23 am Post subject: |
Yep I'm with ya now! No wonder I could not find it works a treat in landscape real shame it don't work in portrait.
many thanks |
Posted: Tue Aug 19, 2008 11:29 am Post subject: |
Maybe I should try version 4.4 as the author is stating below its retained in portrait mode. I would have thought he would have taken it into 4.5 also. I certainly cant get it to do it in 4.5 in portrait!
10/08/2008 Version 4.4
- Added redesigned matching square backgrounds to the main and secondary direction icons for "Full Screen Mode" only.
- The "Full Screen Mode" setting is now retained when switching between landscape and portrait mode and is now the default mode.
- Added a "No-GPS Warning" button to the "Map" screen for the condition where there is a valid route but no GPS device available. |
Posted: Tue Aug 19, 2008 11:52 am Post subject: |
Satmaniac wrote: | Maybe I should try version 4.4 as the author is stating below its retained in portrait mode. I would have thought he would have taken it into 4.5 also. I certainly cant get it to do it in 4.5 in portrait!
I am the author.
It is only the setting which is retained not the actual full screen mode, nothing is missing in 4.5.
By the way, the latest version is 4.6.
linknet |
Posted: Tue Aug 19, 2008 4:01 pm Post subject: |
Hey good stuff thanks for that and the Skin by the way!! It works really well for me I like it a lot, you certainly keep up to speed with it to which is good. Having looked at the landscape view I certainly like that full screen mode obviously not knowing what is involved is it not possible to have it in portrait also? I edited the sound files to add a little attention getter before the camera announcements and that works fine for me too ;-)
Would you happen to have a link to where you upload the latest versions directly as the page I see aint got 4.6 yet?
Great work thanks
Posted: Tue Aug 19, 2008 4:41 pm Post subject: |
Satmaniac wrote: | Hey good stuff thanks for that and the Skin by the way!! It works really well for me I like it a lot, you certainly keep up to speed with it to which is good. Having looked at the landscape view I certainly like that full screen mode obviously not knowing what is involved is it not possible to have it in portrait also? I edited the sound files to add a little attention getter before the camera announcements and that works fine for me too ;-)
Great work thanks
Check out this forum and look down a few posts.
linknet |
Posted: Wed Aug 20, 2008 9:51 am Post subject: |
OK thanks have found the link. Would there be any possibility of Full Screen mode in portrait at any time then? |
Posted: Wed Aug 20, 2008 10:05 am Post subject: |
Satmaniac wrote: | OK thanks have found the link. Would there be any possibility of Full Screen mode in portrait at any time then? |
I've been asked for this many times but what you actually need in portrait mode is more width not height. Increasing the height just gives you more sky which looks pretty but is no use for navigation. Then you have to add more information across the bottom and side of the screen so after all that you actually get less useful map area than before.
linknet |
Posted: Tue Aug 26, 2008 5:32 pm Post subject: |
Like the new square boxes in v4.8 you get to see more map  |
