Pocket GPS World :: View topic - Can't see the Speed cams on DNX8220BT
vienly
PostPosted: Mon Aug 18, 2008 6:31 pm    Post subject: Can't see the Speed cams on DNX8220BT Reply with quote
Hi guys, I've just followed the instructions here
http://www.pocketgpsworld.com/uksafetycameras-kenwood.php
step by step but for some reason I can't seem to see the speed cameras on the map. I used a SD card and it has written the files to the internal memory of the DNX8220BT without a problem, but still it doesn't want to show the POI's, it shows all the other POI's except for the one I have uploaded, any ideas??
vienly
PostPosted: Mon Aug 18, 2008 6:47 pm    Post subject: Reply with quote
err... nevermind, i got it working, for some reason downloading the wrong Garming speedcamera file 'UK Speed Zoned Complete' makes a big difference, correct file was 'UK - Consolidated by Type'
PostPosted: Mon Aug 18, 2008 11:32 pm    Post subject: Reply with quote
it should still work with speed zoned?
remember that if you install any other POIs then it will first remove any already installed - perhaps you installed some other POIs after the speed cameras?
vienly
PostPosted: Tue Aug 19, 2008 9:20 am    Post subject: Reply with quote
I did have some preinstalled before, but then I downloaded the 'UK Speed Zoned Complete' and over wrote the existing files on the Garmin system. It showed all other POI's but not the speed cameras, spent an hour fiddling around with the settings but no joy. Then I followed the Kenwood PDF document which said to use the 'UK - Consolidated by Type' and it worked, strange...
Oh, I didn't install anything after uploading the speed camera files.
22.055 (29 May 24)
