smokey007uk Occasional Visitor
Posted: Wed May 26, 2004 4:07 pm Post subject: gps disabled msg , using a Haicom 303E CF with TOMTOM3 |
all using a ipaq 2210
and a haicom 330E CF gps
and tomtom 3
card picked up on com port 7
the issue i am having is that tomtom just says gps disabled
but the program that came with the gps card shows it to be working fine and finding Satellites
any 1 any ideas
am stuck and lost 8O
cheers Smokey |
dastardly Occasional Visitor
Posted: Wed May 26, 2004 8:25 pm Post subject: Re: gps disabled msg , using a Haicom 303E CF with TOMTOM3 |
smokey007uk wrote: | Hi
and tomtom 3
Hi Smokey,
Com 7 doesn't sound right at all.
I have the same setup, and what I did was this..
Open TT3 and go to the GPS page with a dinky map of the world on it
1. untick the box in the top left hand corner.
2. select 'Haicom GPS' in the top pull-down menu
3. select 'CF_CARD GENERIC' in the lower pull down menu.
4. retick the box
5. Fire it up and wait about 90 secs, and sats start to appear
......well it works for me :D
Good luck mate
John _________________ ipac 2210, Integral 128Mb, Haicom 303E CF (& TT wired), Fugawi, TT3 & POI Warner
Nuvi 610T on my motorbike
Tomtom 720 in my car |
DavidW Pocket GPS Moderator
Posted: Wed May 26, 2004 9:17 pm Post subject: |
Confusingly, Haicom GPS is incorrect for an Evermore chipset GPS (such as your HI-303E). You should use NMEA 0183v2 4800 instead. Haicom GPS is for SiRF chipset GPSes; it sends SiRF commands to the GPS which could confuse an Evermore chipset.
CF_CARD_GENERIC is the correct port to use for a Haicom CompactFlash GPS in TomTom products.
David |
Posted: Thu May 27, 2004 10:07 am Post subject: |
DavidW wrote: | Confusingly, Haicom GPS is incorrect for an Evermore chipset GPS (such as your HI-303E). You should use NMEA 0183v2 4800 instead. Haicom GPS is for SiRF chipset GPSes; it sends SiRF commands to the GPS which could confuse an Evermore chipset.
CF_CARD_GENERIC is the correct port to use for a Haicom CompactFlash GPS in TomTom products |
Wow, yup that's better - Now it's seeing satellites much quicker.
Thanks David _________________ ipac 2210, Integral 128Mb, Haicom 303E CF (& TT wired), Fugawi, TT3 & POI Warner
