Pocket GPS World :: View topic - intalling speed cams
WELLHEADS
PostPosted: Thu Aug 14, 2008 9:59 am    Post subject: intalling speed cams Reply with quote
i am going to subscribe to speed cameras but before i install them do i have to remove my old database or does it over write them.
regards dave
Daggers
PostPosted: Thu Aug 14, 2008 10:07 am    Post subject: Reply with quote
The PGPSW camera database is completely separate to the TomTom version. You can have either or both databases installed and operational.
The normal advice is to leave both running for a period until you have convinced yoursel that the PGPSW version is superior. At that point, you can turn off the Tomtom version!
WELLHEADS
PostPosted: Thu Aug 14, 2008 10:16 am    Post subject: thanks daggers Reply with quote
thanks this is usefull to know but i allready have an old pgps database installed as well as my tom tom so do i remove theold pgps data before i put the new one in
PostPosted: Thu Aug 14, 2008 8:48 pm    Post subject: Reply with quote
You might as well...
When you update the database normally, you just paste the new files into your map folder and they overwrite the old ones (as they have the same name).
This depends on you always downloading the same version of the database (all in one, consolidated by type or full speed-zoned).
However, as you have an old version, it might have a different selection of files, so it's probably best to start from scratch.
Using Windows Explorer simply delete any files in the map folder that start with "PocketGPS....".
WELLHEADS
PostPosted: Thu Aug 14, 2008 9:06 pm    Post subject: THANKS Reply with quote
i have done as you said and everything works fine.
thanks for your help
22.055 (29 May 24)
