Pocket GPS World :: View topic - Any Mio Magiciancs out there ? Vanishing satellites
Goto page Previous  1, 2
wiseninja
PostPosted: Thu Aug 07, 2008 9:08 am    Post subject: Reply with quote
I didn't realise that the time / date was important
I did a full reset on the device several days ago and it thinks it's living in 2003
will corrct the time and place outside in clear sky for an hour + repost more data
I'm in Eastern Scotland (Fife) near St Andrews
My exact location is Ladybank
thanks again for showing an interest
by the way
if this helps, I have a perfectly working MioA201
would posting data from that help out at all ?
PostPosted: Thu Aug 07, 2008 9:35 am    Post subject: Reply with quote
The data and time information is what the receiver is picking up, the fact it is dead (not changing) doesn't look good, after a few minutes outside I would expect to see the correct date/ time displayed if the GPS were working correctly, a position fix could take much longer (circa 20 minutes).
Can you post the Syntax from the GPS after the device has been outside running for at least ten minutes - MIke
Border_Collie
PostPosted: Thu Aug 07, 2008 2:26 pm    Post subject: Reply with quote
Look HERE to read about NMEA.
e.g.
$GPGGA,123519,4807.038,N,01131.000,E,1,08,0.9,545.4,M,46.9,M,,*47
Where:
GGA Global Positioning System Fix Data
123519 Fix taken at 12:35:19 UTC
4807.038,N Latitude 48 deg 07.038' N
01131.000,E Longitude 11 deg 31.000' E
1 Fix quality: 0 = invalid
1 = GPS fix (SPS)
2 = DGPS fix
3 = PPS fix
4 = Real Time Kinematic
5 = Float RTK
6 = estimated (dead reckoning) (2.3 feature)
7 = Manual input mode
8 = Simulation mode
08 Number of satellites being tracked
0.9 Horizontal dilution of position
545.4,M Altitude, Meters, above mean sea level
46.9,M Height of geoid (mean sea level) above WGS84
ellipsoid
(empty field) time in seconds since last DGPS update
(empty field) DGPS station ID number
*47 the checksum data, always begins with *
wiseninja
PostPosted: Thu Aug 07, 2008 6:02 pm    Post subject: Reply with quote
here is data with gps left out in the car a bit overcast for quite a while
the 3 readings were taken within 2 minutes of each other
1
$GPGSV,3,1,12,21,00,000,,10,00,000,,25,00,000,,09,00,000,*74
$GPGSV,3,2,12,07,00,000,,03,00,000,,11,00,000,,15,00,000,*7B
$GPGSV,3,3,12,02,00,000,,30,00,000,,01,00,000,,26,00,000,*7E
$GPRMC,034207.185,V,,,,,,,250104,,,N*41
$GPGGA,034208.185,,,,,0,00,50.0,,M,,,,0000*2F
$GPGSA,A,1,,,,,,,,,,,,,50.0,50.0,50.0*05
$GPRMC,034208.185,V,,,,,,,250104,,,N*4E
$GPGGA,034209.184,,,,,0,00,50.0,,M,,,,0000*2F
$GPRMC,034209.184,V,,,,,,,250104,,,N*44
$GPGGA,034213.184,,,,,0,00,50.0,,M,,,,0000*24
$GPRMC,034213.184,V,,,,,,,250104,,,N*45
$GPGGA,034214.184,,,,,0,00,50.0,,M,,,,0000*23
$GPRMC,034214.184,V,,,,,,,250104,,,N*42
$GPGGA,034215.184,,,,,0,00,50.0,,M,,,,0000*22
$GPRMC,034215.184,V,,,,,,,250104,,,N*43
$GPGGA,034216.184,,,,,0,00,50.0,,M,,,,0000*21
$GPRMC,034216.184,V,,,,,,,250104,,,N*40
$GPGGA,034217.184,,,,,0,00,50.0,,M,,,,0000*20
$GPRMC,034217.184,V,,,,,,,250104,,,N*41
$GPGGA,034218.184,,,,,0,00,50.0,,M,,,,0000*2F
$GPRMC,034218.184,V,,,,,,,250104,,,N*4E
$GPGGA,034219.184,,,,,0,00,50.0,,M,,,,0000*2E
$GPRMC,034219.184,V,,,,,,,250104,,,N*4F
$GPGGA,034220.184,,,,,0,00,50.0,,M,,,,0000*24
$GPRMC,034220.184,V,,,,,,,250104,,,N*45
$GPGGA,034221.184,,,,,0,00,50.0,,M,,,,0000*25
$GPRMC,034221.184,V,,,,,,,250104,,,N*44
$GPGGA,034222.184,,,,,0,00,50.0,,M,,,,0000*26
2
$GPGGA,034229.183,,,,,0,00,50.0,,M,,,,0000*2A
$GPRMC,034229.183,V,,,,,,,250104,,,N*4B
$GPGGA,034230.183,,,,,0,00,50.0,,M,,,,0000*22
$GPRMC,034230.183,V,,,,,,,250104,,,N*43
$GPGGA,034231.183,,,,,0,00,50.0,,M,,,,0000*23
$GPRMC,034231.183,V,,,,,,,250104,,,N*42
$GPGGA,034232.183,,,,,0,00,50.0,,M,,,,0000*20
$GPRMC,034232.183,V,,,,,,,250104,,,N*41
$GPGGA,034233.183,,,,,0,00,50.0,,M,,,,0000*21
$GPRMC,034233.183,V,,,,,,,250104,,,N*40
$GPGGA,034234.183,,,,,0,00,50.0,,M,,,,0000*26
3
$GPRMC,034242.182,V,,,,,,,250104,,,N*47
$GPGGA,034243.182,,,,,0,00,50.0,,M,,,,0000*27
$GPRMC,034243.182,V,,,,,,,250104,,,N*46
$GPGGA,034244.182,,,,,0,00,50.0,,M,,,,0000*20
$GPRMC,034244.182,V,,,,,,,250104,,,N*41
$GPGGA,034245.182,,,,,0,00,50.0,,M,,,,0000*21
$GPRMC,034245.182,V,,,,,,,250104,,,N*40
$GPGGA,034246.182,,,,,0,00,50.0,,M,,,,0000*22
$GPRMC,034246.182,V,,,,,,,250104,,,N*43
$GPGGA,034247.182,,,,,0,00,50.0,,M,,,,0000*23
$GPRMC,034247.182,V,,,,,,,250104,,,N*42
$GPGGA,034248.182,,,,,0,00,50.0,,M,,,,0000*2C
$GPRMC,034248.182,V,,,,,,,250104,,,N*4D
$GPGGA,034249.182,,,,,0,00,50.0,,M,,,,0000*2D
$GPRMC,034249.182,V,,,,,,,250104,,,N*4C
$GPGGA,034250.182,,,,,0,00,50.0,,M,,,,0000*25
$GPRMC,034250.182,V,,,,,,,250104,,,N*44
$GPGGA,034251.182,,,,,0,00,50.0,,M,,,,0000*24
$GPRMC,034251.182,V,,,,,,,250104,,,N*45
$GPGGA,034252.182,,,,,0,00,50.0,,M,,,,0000*27
$GPRMC,034252.182,V,,,,,,,250104,,,N*46
$GPGGA,034253.182,,,,,0,00,50.0,,M,,,,0000*26
$GPRMC,034253.182,V,,,,,,,250104,,,N*47
$GPGGA,034254.182,,,,,0,00,50.0,,M,,,,0000*21
$GPRMC,034254.182,V,,,,,,,250104,,,N*40
$GPGGA,034255.182,,,,,0,00,50.0,,M,,,,0000*20
$GPRMC,034255.182,V,,,,,,,250104,,,N*41
$GPGGA,034256.182,,,,,0,00,50.0,,M,,,,0000*23
$GPRMC,034256.182,V,,,,,,,250104,,,N*42
$GPGGA,034257.182,,,,,0,00,50.0,,M,,,,0000*22
$GPRMC,034257.182,V,,,,,,,250104,,,N*43
$GPGGA,034258.181,,,,,0,00,50.0,,M,,,,0000*2E
$GPRMC,034258.181,V,,,,,,,250104,,,N*4F
$GPGGA,034259.181,,,,,0,00,50.0,,M,,,,0000*2F
$GPRMC,034259.181,V,,,,,,,250104,,,N*4E
$GPGGA,034300.181,,,,,0,00,50.0,,M,,,,0000*22
$GPRMC,034300.181,V,,,,,,,250104,,,N*43
$GPGGA,034301.181,,,,,0,00,50.0,,M,,,,0000*23
$GPRMC,034301.181,V,,,,,,,250104,,,N*42
$GPGGA,034302.181,,,,,0,00,50.0,,M,,,,0000*20
$GPRMC,034302.181,V,,,,,,,250104,,,N*41
$GPGGA,034303.181,,,,,0,00,50.0,,M,,,,0000*21
$GPRMC,034303.181,V,,,,,,,250104,,,N*40
$GPGGA,034304.181,,,,,0,00,50.0,,M,,,,0000*26
$GPRMC,034304.181,V,,,,,,,250104,,,N*47
$GPGGA,034305.181,,,,,0,00,50.0,,M,,,,0000*27
$GPRMC,034305.181,V,,,,,,,250104,,,N*46
$GPGGA,034306.181,,,,,0,00,50.0,,M,,,,0000*24
$GPRMC,034306.181,V,,,,,,,250104,,,N*45
$GPGGA,034307.181,,,,,0,00,50.0,,M,,,,0000*25
$GPRMC,034307.181,V,,,,,,,250104,,,N*44
$GPGGA,034308.181,,,,,0,00,50.0,,M,,,,0000*2A
$GPRMC,034308.181,V,,,,,,,250104,,,N*4B
$GPGGA,034309.181,,,,,0,00,50.0,,M,,,,0000*2B
$GPRMC,034309.181,V,,,,,,,250104,,,N*4A
$GPGGA,034310.181,,,,,0,00,50.0,,M,,,,0000*23
$GPRMC,034310.181,V,,,,,,,250104,,,N*42
$GPGGA,034311.181,,,,,0,00,50.0,,M,,,,0000*22
$GPRMC,034311.181,V,,,,,,,250104,,,N*43
$GPGGA,034312.181,,,,,0,00,50.0,,M,,,,0000*21
$GPRMC,034312.181,V,,,,,,,250104,,,N*40
$GPGGA,034313.181,,,,,0,00,50.0,,M,,,,0000*20
$GPRMC,034313.181,V,,,,,,,250104,,,N*41
$GPGGA,034314.180,,,,,0,00,50.0,,M,,,,0000*26
$GPRMC,034314.180,V,,,,,,,250104,,,N*47
$GPGGA,034315.180,,,,,0,00,50.0,,M,,,,0000*27
$GPRMC,034315.180,V,,,,,,,250104,,,N*46
$GPGGA,034316.180,,,,,0,00,50.0,,M,,,,0000*24
$GPRMC,034316.180,V,,,,,,,250104,,,N*45
$GPGGA,034317.180,,,,,0,00,50.0,,M,,,,0000*25
$GPRMC,034317.180,V,,,,,,,250104,,,N*44
$GPGGA,034318.180,,,,,0,00,50.0,,M,,,,0000*2A
$GPRMC,034318.180,V,,,,,,,250104,,,N*4B
$GPGGA,034319.180,,,,,0,00,50.0,,M,,,,0000*2B
$GPRMC,034319.180,V,,,,,,,250104,,,N*4A
$GPGGA,034320.180,,,,,0,00,50.0,,M,,,,0000*21
$GPRMC,034320.180,V,,,,,,,250104,,,N*40
$GPGGA,034321.180,,,,,0,00,50.0,,M,,,,0000*20
$GPRMC,034321.180,V,,,,,,,250104,,,N*41
$GPGGA,034322.180,,,,,0,00,50.0,,M,,,,0000*23
$GPRMC,034322.180,V,,,,,,,250104,,,N*42
$GPGGA,034323.180,,,,,0,00,50.0,,M,,,,0000*22
$GPRMC,034323.180,V,,,,,,,250104,,,N*43
$GPGGA,034324.180,,,,,0,00,50.0,,M,,,,0000*25
$GPRMC,034324.180,V,,,,,,,250104,,,N*44
$GPGGA,034325.180,,,,,0,00,50.0,,M,,,,0000*24
$GPRMC,034325.180,V,,,,,,,250104,,,N*45
$GPGGA,034326.180,,,,,0,00,50.0,,M,,,,0000*27
$GPRMC,034326.180,V,,,,,,,250104,,,N*46
$GPGGA,034327.180,,,,,0,00,50.0,,M,,,,0000*26
$GPRMC,034327.180,V,,,,,,,250104,,,N*47
$GPGGA,034328.180,,,,,0,00,50.0,,M,,,,0000*29
$GPRMC,034328.180,V,,,,,,,250104,,,N*48
$GPGGA,034329.180,,,,,0,00,50.0,,M,,,,0000*28
$GPRMC,034329.180,V,,,,,,,250104,,,N*49
$GPGGA,034330.180,,,,,0,00,50.0,,M,,,,0000*20
$GPRMC,034330.180,V,,,,,,,250104,,,N*41
$GPGGA,034331.179,,,,,0,00,50.0,,M,,,,0000*27
$GPRMC,034331.179,V,,,,,,,250104,,,N*46
$GPGGA,034332.179,,,,,0,00,50.0,,M,,,,0000*24
$GPRMC,034332.179,V,,,,,,,250104,,,N*45
$GPGGA,034333.179,,,,,0,00,50.0,,M,,,,0000*25
$GPRMC,034333.179,V,,,,,,,250104,,,N*44
$GPGGA,034334.179,,,,,0,00,50.0,,M,,,,0000*22
$GPRMC,034334.179,V,,,,,,,250104,,,N*43
$GPGGA,034335.179,,,,,0,00,50.0,,M,,,,0000*23
$GPRMC,034335.179,V,,,,,,,250104,,,N*42
$GPGGA,034336.179,,,,,0,00,50.0,,M,,,,0000*20
$GPRMC,034336.179,V,,,,,,,250104,,,N*41
$GPGGA,034337.179,,,,,0,00,50.0,,M,,,,0000*21
$GPRMC,034337.179,V,,,,,,,250104,,,N*40
$GPGGA,034338.179,,,,,0,00,50.0,,M,,,,0000*2E
$GPRMC,034338.179,V,,,,,,,250104,,,N*4F
$GPGGA,034339.179,,,,,0,00,50.0,,M,,,,0000*2F
$GPRMC,034339.179,V,,,,,,,250104,,,N*4E
$GPGGA,034340.179,,,,,0,00,50.0,,M,,,,0000*21
$GPRMC,034340.179,V,,,,,,,250104,,,N*40
$GPGGA,034341.179,,,,,0,00,50.0,,M,,,,0000*20
$GPRMC,034341.179,V,,,,,,,250104,,,N*41
$GPGGA,034342.179,,,,,0,00,50.0,,M,,,,0000*23
$GPRMC,034342.179,V,,,,,,,250104,,,N*42
$GPGGA,034343.179,,,,,0,00,50.0,,M,,,,0000*22
$GPRMC,034343.179,V,,,,,,,250104,,,N*43
$GPGGA,034344.179,,,,,0,00,50.0,,M,,,,0000*25
$GPRMC,034344.179,V,,,,,,,250104,,,N*44
$GPGGA,034345.179,,,,,0,00,50.0,,M,,,,0000*24
$GPRMC,034345.179,V,,,,,,,250104,,,N*45
$GPGGA,034346.179,,,,,0,00,50.0,,M,,,,0000*27
$GPRMC,034346.179,V,,,,,,,250104,,,N*46
$GPGGA,034347.178,,,,,0,00,50.0,,M,,,,0000*27
$GPRMC,034347.178,V,,,,,,,250104,,,N*46
$GPGGA,034348.178,,,,,0,00,50.0,,M,,,,0000*28
$GPRMC,034348.178,V,,,,,,,250104,,,N*49
$GPGGA,034349.178,,,,,0,00,50.0,,M,,,,0000*29
$GPRMC,034349.178,V,,,,,,,250104,,,N*48
$GPGGA,034350.178,,,,,0,00,50.0,,M,,,,0000*21
$GPRMC,034350.178,V,,,,,,,250104,,,N*40
$GPGGA,034351.178,,,,,0,00,50.0,,M,,,,0000*20
$GPRMC,034351.178,V,,,,,,,250104,,,N*41
$GPGGA,034352.178,,,,,0,00,50.0,,M,,,,0000*23
$GPRMC,034352.178,V,,,,,,,250104,,,N*42
$GPGGA,034353.178,,,,,0,00,50.0,,M,,,,0000*22
$GPRMC,034353.178,V,,,,,,,250104,,,N*43
$GPGGA,034354.178,,,,,0,00,50.0,,M,,,,0000*25
$GPRMC,034354.178,V,,,,,,,250104,,,N*44
$GPGGA,034355.178,,,,,0,00,50.0,,M,,,,0000*24
$GPRMC,034355.178,V,,,,,,,250104,,,N*45
$GPGGA,034356.178,,,,,0,00,50.0,,M,,,,0000*27
$GPRMC,034356.178,V,,,,,,,250104,,,N*46
$GPGGA,034357.178,,,,,0,00,50.0,,M,,,,0000*26
$GPRMC,034357.178,V,,,,,,,250104,,,N*47
$GPGGA,034358.178,,,,,0,00,50.0,,M,,,,0000*29
$GPRMC,034358.178,V,,,,,,,250104,,,N*48
$GPGGA,034359.178,,,,,0,00,50.0,,M,,,,0000*28
$GPRMC,034359.178,V,,,,,,,250104,,,N*49
$GPGGA,034400.178,,,,,0,00,50.0,,M,,,,0000*23
$GPRMC,034400.178,V,,,,,,,250104,,,N*42
$GPGGA,034401.178,,,,,0,00,50.0,,M,,,,0000*22
$GPRMC,034401.178,V,,,,,,,250104,,,N*43
$GPGGA,034402.178,,,,,0,00,50.0,,M,,,,0000*21
$GPRMC,034402.178,V,,,,,,,250104,,,N*40
$GPGGA,034403.177,,,,,0,00,50.0,,M,,,,0000*2F
$GPRMC,034403.177,V,,,,,,,250104,,,N*4E
$GPGGA,034404.177,,,,,0,00,50.0,,M,,,,0000*28
$GPRMC,034404.177,V,,,,,,,250104,,,N*49
$GPGGA,034405.177,,,,,0,00,50.0,,M,,,,0000*29
$GPRMC,034405.177,V,,,,,,,250104,,,N*48
$GPGGA,034406.177,,,,,0,00,50.0,,M,,,,0000*2A
$GPRMC,034406.177,V,,,,,,,250104,,,N*4B
$GPGGA,034407.177,,,,,0,00,50.0,,M,,,,0000*2B
$GPRMC,034407.177,V,,,,,,,250104,,,N*4A
$GPGGA,034408.177,,,,,0,00,50.0,,M,,,,0000*24
$GPRMC,034408.177,V,,,,,,,250104,,,N*45
$GPGGA,034409.177,,,,,0,00,50.0,,M,,,,0000*25
$GPRMC,034409.177,V,,,,,,,250104,,,N*44
$GPGGA,034410.177,,,,,0,00,50.0,,M,,,,0000*2D
$GPRMC,034410.177,V,,,,,,,250104,,,N*4C
$GPGGA,034411.177,,,,,0,00,50.0,,M,,,,0000*2C
$GPRMC,034411.177,V,,,,,,,250104,,,N*4D
$GPGGA,034412.177,,,,,0,00,50.0,,M,,,,0000*2F
$GPRMC,034412.177,V,,,,,,,250104,,,N*4E
$GPGGA,034413.177,,,,,0,00,50.0,,M,,,,0000*2E
$GPRMC,034413.177,V,,,,,,,250104,,,N*4F
$GPGGA,034414.177,,,,,0,00,50.0,,M,,,,0000*29
$GPRMC,034414.177,V,,,,,,,250104,,,N*48
$GPGGA,034415.177,,,,,0,00,50.0,,M,,,,0000*28
$GPRMC,034415.177,V,,,,,,,250104,,,N*49
$GPGGA,034416.177,,,,,0,00,50.0,,M,,,,0000*2B
$GPRMC,034416.177,V,,,,,,,250104,,,N*4A
$GPGGA,034417.177,,,,,0,00,50.0,,M,,,,0000*2A
$GPRMC,034417.177,V,,,,,,,250104,,,N*4B
$GPGGA,034418.177,,,,,0,00,50.0,,M,,,,0000*25
$GPRMC,034418.177,V,,,,,,,250104,,,N*44
$GPGGA,034419.177,,,,,0,00,50.0,,M,,,,0000*24
$GPRMC,034419.177,V,,,,,,,250104,,,N*45
$GPGGA,034420.176,,,,,0,00,50.0,,M,,,,0000*2F
$GPRMC,034420.176,V,,,,,,,250104,,,N*4E
$GPGGA,034421.176,,,,,0,00,50.0,,M,,,,0000*2E
$GPRMC,034421.176,V,,,,,,,250104,,,N*4F
$GPGGA,034422.176,,,,,0,00,50.0,,M,,,,0000*2D
$GPRMC,034422.176,V,,,,,,,250104,,,N*4C
$GPGGA,034423.176,,,,,0,00,50.0,,M,,,,0000*2C
$GPRMC,034423.176,V,,,,,,,250104,,,N*4D
$GPGGA,034424.176,,,,,0,00,50.0,,M,,,,0000*2B
$GPRMC,034424.176,V,,,,,,,250104,,,N*4A
$GPGGA,034425.176,,,,,0,00,50.0,,M,,,,0000*2A
PostPosted: Thu Aug 07, 2008 6:52 pm    Post subject: Reply with quote
Its dead, time to consider a new device, or go back to page one and read the post that mentions a loose connector for the GPS aerial, it is worth a try and you have little to lose at this stage - Mike
Border_Collie
PostPosted: Thu Aug 07, 2008 8:29 pm    Post subject: Reply with quote
You'll find your default NMEA settings on the Mio P350 and the 168, when checked with WinfastCE, are
GGA 1, GLL 0, GSA 5, GSV 5, VTG 1, MSS 0, User 0, User 0, User 0.
I notice the VTG is missing in your data. So.....
Tap on Tools - Command - NMEA and change the settings to: -
GGA 1, GLL 1, GSA 1, GSV 5, VTG 1, MSS 0, User 0, User 1, User 0.
Tap on OK.
left out in the car
Now go outside under a clear view of the sky. You should start getting locks quite soon.
My Mio168 would rarely lock on inside my car with an athermic windscreen. Has yours one? Peugeot, Citroen, Renault, to name a few. Once you have a lock oustide the car the athermic screen doesn't make much difference.
DON'T mess around with the SiRF settings.
Having said that, if you still have no luck with the above settings, outside your car, then using Winfast change to SiRF, check the readout to see if information is being received, then change back to NMEA. It may take several tries but will go back.
Don't forget to close Winfast make sure you go to Tools - Disconnect, then Tools - Exit. DON'T use the 'X' top right or Winfast will not release the port and TT won't work.
Look at THIS post I just found.
wiseninja
PostPosted: Thu Aug 07, 2008 8:52 pm    Post subject: Reply with quote
I opened up my MIo case and checked the cable connection which was solid - no problem
so obviously it seems that the actual GPS receiver is knackered
Tap on OK.
I had these as my settings for NMEA - unfortunately it made no difference
NO ATHERMIC SCREEN ON MY CAR BUT DID TAKE IT OUTSIDE AS ADVISED
with no change in response
I switched to SIRF and got data from it which I didn't understand
went back no NMEA and got similar readings to the data printed out in previous posts
any final ideas before I break the news to my dad that his GPS is knackered ?
robertn
PostPosted: Thu Aug 07, 2008 9:57 pm    Post subject: Reply with quote
As Mike siad - it's hosed. Personally I would bin it, or as the PDA bit bit still works, $1 reserve on ebay and be honest about the GPS.
If after 3 hours it is not reporting the time (See the GPRMC message), then it has not evne managed to get the signal from one satalite (Are you in an underground bunker by any chance? )
One last option - very very slim, but you have nohing to loose.
Turn the PDA OFF using the switch on the back. Pull apart the GPS Module, again, and look for the battary backup. It is usually a biggish round can, like a watch battery. Find the the two terminal from that and short it out for 10 seconds (paper clip is good). While doing this, make sure things don't get too hot. Wear safety glasses and don't breath any smoke if it comes out.
If the smoke came out, well, it was worth a crack ........
If not, put it all together, and try ONE more time, then bin it.
CaptainDrift
PostPosted: Thu Aug 21, 2008 7:32 pm    Post subject: Reply with quote
Is winfast better than the GPS info tool?
Page 2 of 2
22.071 (03 Jul 24)
