Pocket GPS World :: View topic - Auto turn on With ignition
fastblatt
PostPosted: Mon Aug 04, 2008 4:15 pm    Post subject: Auto turn on With ignition Reply with quote
Hi. Does anyone know if it is possible to hardwire a tomtom one v2 to a cars ignition so that the unit switches on with the ignition and off when the car is switched off?
PostPosted: Mon Aug 04, 2008 4:22 pm    Post subject: Reply with quote
yeah, those were the days. That's a feature that was removed by TomTom after the problems with the 910 mount.
fastblatt
PostPosted: Mon Aug 04, 2008 5:00 pm    Post subject: Reply with quote
OK. But has anyone handy with a soldering iron managed to get over this since then?
PostPosted: Mon Aug 04, 2008 5:32 pm    Post subject: Reply with quote
No, it is not possible AFAIK - Mike
PostPosted: Mon Aug 04, 2008 6:28 pm    Post subject: Reply with quote
Well, if you really wanted to, you could make a circuit that looked at the ignition switch and closed a relay for three seconds. The contacts of that could be wired directly across the TomTom's power switch.
Not for the faint-hearted though.
BodgerBaz
PostPosted: Tue Aug 05, 2008 7:09 am    Post subject: Reply with quote
I use the good old fashioned GO 510/710 and it will turn on with the ignition but stays on when the ignition is turned off. Not too much of a problem as I need to remove it from the windscreen when I get out anyway.
253
PostPosted: Tue Aug 05, 2008 9:15 am    Post subject: Reply with quote
Question
My trusty bulky TT710 switches on and off when connected to the ciggy lighter and engine is turned on and off. get a 10 sec countdown to cancel the switch off.
This should be a standard feature really, but like you say, I take mine out of the car as well.
PostPosted: Tue Aug 05, 2008 9:43 am    Post subject: Reply with quote
as lutz said though, they released a rubbish mount for the 910 whereby the connections would come apart far to easily so you would constantly get the 10 second count-down.
great that, instead of dealing with the problem (rubbish mount) they just hid the effects of it...
PostPosted: Tue Aug 05, 2008 11:27 am    Post subject: Reply with quote
I'm sorry, but I've never had a problem with the 910 mount. Rolling Eyes
Well, I'm not sorry really, I'm rather glad that mine is OK. Smile
There is an option that you need to tick on the 2nd page of Battery saving preferences
BodgerBaz
PostPosted: Wed Aug 06, 2008 7:02 am    Post subject: Reply with quote
KEWL. Thanks Richard I've found it Wink
tenorplayer
PostPosted: Wed Aug 06, 2008 3:27 pm    Post subject: Reply with quote
my 910 mount used to switch on and off when hitting bumps etc ( a common fault I believe) but TT sent me an improved model mount and brill so far for nigh on 2 years (give or take )
fastblatt
PostPosted: Wed Aug 06, 2008 7:07 pm    Post subject: Reply with quote
I saw the bit about the battery preferences and thought that would help with what I want to do but I don't think my ONE V2 has it. Well.... I can't find it.
BodgerBaz
PostPosted: Thu Aug 07, 2008 7:26 am    Post subject: Reply with quote
It sounds as though yours is running with the 'fewer options' facility. The battery option is on page 6 of 7.
If you don't have 7 pages then try clicking on Change Preferences | Show more Options (on page 3 of 3).
mikewall
PostPosted: Thu Aug 07, 2008 9:25 am    Post subject: Reply with quote
Or anyone with normal sized fingers, perfect eye sight, your talking keyhole surgery on the TT, and forget the warrenty if/when it goes wrong! Best option would be to get a 910!
View user's profile Send private message AIM Address
PostPosted: Thu Aug 07, 2008 9:31 am    Post subject: Reply with quote
A modification like this could be done, but unless you are used to working with surface mount electronics and use of very fine tip soldering irons then leave this idea well alone.
Another thing to consider is the duration the button needs to be pressed, a couple of seconds is the norm, 7,481 needed a five second press and on some newer units the on/ off button doubles as the reset button (when you press it for 15 seconds) - so make sure whatever you wire in for the auto on/ off can accommodate the above - Mike
22.063 (19 Jun 24)
