Pocket GPS World :: View topic - Kenwood DNX5220 Wont see POI's
scoobywagonp1
PostPosted: Sun Aug 03, 2008 5:23 pm    Post subject: Kenwood DNX5220 Wont see POI's Reply with quote
Hi All,
Have a Kenwood DNX5220, downloaded speed camera's burned to Garmin folder on CD, won't load POI's anyone got any tips?
Many Thanks
Paul
PaulB2005
PostPosted: Sun Aug 03, 2008 6:19 pm    Post subject: Reply with quote
Hi and welcome.
The instructions are here
Did you follow these?
PaulB2005
PostPosted: Sun Aug 03, 2008 6:32 pm    Post subject: Reply with quote
If so, did you also follow the last step?
Displaying Speed Cameras on Kenwood units
Ensure that you have Proximity Alerts turned on in the units settings
If you have a unit with the Garmin/Cyclops camera database installed then you may want to turn off alerts for this database to avoid duplicate warnings.
scoobywagonp1
PostPosted: Sun Aug 03, 2008 11:49 pm    Post subject: Reply with quote
Thanks for the reply's, yes followed the instructions, when I put the CD in the machine with file in Garmin folder, nothing happens, it doesn't ask to update
Tried 3 CD's now, no luck
PaulB2005
PostPosted: Mon Aug 04, 2008 12:11 am    Post subject: Reply with quote
Burn the Garmin folder to CD-R and finalise
Did you "Finalise" the CD?
Do you what software you are burning the CDs with as the method varies from program to program? Some you will see it as an option, other you need to do it after you burn the CD.
scoobywagonp1
PostPosted: Mon Aug 04, 2008 9:06 am    Post subject: Reply with quote
Yep I did finalise the CD, used Windows Vista standard software, tried CD in another old PC & it see's the file, very strange Rolling Eyes
Wonder if I should give it a go with the old XP machine?
scoobywagonp1
PostPosted: Thu Aug 07, 2008 12:27 am    Post subject: Reply with quote
Fixed it, burned the disk with Nero, problem solved, seems it doesnt like the Windows Vista software?
Thanks for all your reply's Very Happy
Paul
PaulB2005
PostPosted: Thu Aug 07, 2008 12:35 am    Post subject: Reply with quote
Excellent. Sorry i missed your post on Monday. I suspect it's the built in Burning Software not Finalising properly or in the required manner..
PostPosted: Thu Aug 07, 2008 12:53 am    Post subject: Reply with quote
Never trust Vista to do a job that a decent alternate application such as Nero can accomplish - Vista isn't bad, but disk burning isn't one of its strongest points - Mike
scoobywagonp1
PostPosted: Thu Aug 07, 2008 11:11 am    Post subject: Reply with quote
Know what your saying with Vista Very Happy
Anyway all sorted now & thanks
fokkerjet
PostPosted: Sat Aug 09, 2008 5:20 pm    Post subject: Reply with quote
I am also having problems loading the speed camera database on my DNX5220BT unit. I have followed the instructions exactly and burned the "Garmin" folder containing the file that was produced by POILoader software. I made sure that the disk was finalised. I am using Ashampoo 2008. The finalise setting was ticked- the disk is verified as OK.
When I put the disk into the Kenwood unit, it plays a series of sounds- like white noise- and that is it! No offer to load POI's!
I tried burning a couple of different disks and I get the same each time. I am stuck as to what to do now- does anyone have any idea? I am sure that the disk is burned correctly. I don't have Nero software to try that.
PaulB2005
PostPosted: Sat Aug 09, 2008 5:38 pm    Post subject: Reply with quote
Sounds like it's trying to play the CD as an Audio disc and not a data disk.
Was the disk definitely burnt as a Data Disk?
Have you tried putting the unit into Sat Nav mode (sorry don't have a manual here) to see if it makes a difference?
fokkerjet
PostPosted: Sat Aug 09, 2008 6:31 pm    Post subject: Reply with quote
It is definitely recorded as a data disk.
I tried to load the disk into the Kenwood unit in all modes- definitely NAV. It just does what I said, namely plays it as some kind of audio track. I tried burning again using XP and got the same response.
I have no idea why this is not working!
PaulB2005
PostPosted: Sat Aug 09, 2008 7:02 pm    Post subject: Reply with quote
It's possible it the software. You could try a 15 Day TRIAL version of Nero fromhere
PaulB2005
PostPosted: Sat Aug 09, 2008 7:14 pm    Post subject: Reply with quote
The only Ashampoo 2008 i can find is the Office Software.
What is the exact name and vesion of Ashampoo software are you using to burn the CDs?
22.055 (29 May 24)
