Pocket GPS World :: View topic - New Online route resource.......
fatchef
PostPosted: Thu Jul 31, 2008 10:26 pm    Post subject: New Online route resource....... Reply with quote
Outdoorsmagic have just released their new online route planner/share’r/anything else you want to do with a route, thingy, it can be found here:
www.outdoorsmagic.com/routes/default.aspx?v=7
I just done a quick test of a GPX file download and it appears to be in a format that the A10 is happy with - without going through a converter.
Hope you find it useful
Jason
PS Apologies for the lack of the correct technical terminology Smile
nonoftheabove
PostPosted: Fri Aug 01, 2008 9:24 am    Post subject: Reply with quote
thanksa for the heads up Very Happy
i note there is a walk posted for the dales; just the route i wish to use
in the near future.
4ndynorfolk
PostPosted: Fri Aug 01, 2008 11:51 am    Post subject: Reply with quote
What am I doing wrong?
Downloaded the GPX file for a walk from Tideswell to pc, copied it to device using drag and drop, import and copying directly to SD card via card reader. In all three instances the file is visible in satsync (latest version) but not visible on device.
I have found previously that renaming gpx files on the pc has no effect when re-loaded onto device, so I conclude that there must be a "header" in the gpx that is required to be visible on the Satmap.
fatchef
PostPosted: Fri Aug 01, 2008 12:09 pm    Post subject: Reply with quote
Just tried the same route (tideswell) and its all fine on my unit! Used the "import" and saved to internal memory.
Obvious question but have you unplugged from USB and turned A10 off then on....?
Jason
4ndynorfolk
PostPosted: Fri Aug 01, 2008 3:41 pm    Post subject: Reply with quote
Thanks for the advice Fatchef.
Worked this time.
Interestingly, the file is called 151.gpx when downloaded, appears as 151.map in satsync and route 0001 on the Satmap.
22.124 (26 Dec 24)
