fatchef Occasional Visitor
Posted: Thu Jul 31, 2008 10:26 pm Post subject: New Online route resource....... |
Outdoorsmagic have just released their new online route planner/share’r/anything else you want to do with a route, thingy, it can be found here:
www.outdoorsmagic.com/routes/default.aspx?v=7
I just done a quick test of a GPX file download and it appears to be in a format that the A10 is happy with - without going through a converter.
Hope you find it useful
Jason
PS Apologies for the lack of the correct technical terminology |
nonoftheabove Regular Visitor
Posted: Fri Aug 01, 2008 9:24 am Post subject: |
thanksa for the heads up
i note there is a walk posted for the dales; just the route i wish to use
in the near future. |
4ndynorfolk Regular Visitor
Posted: Fri Aug 01, 2008 11:51 am Post subject: |
What am I doing wrong?
Downloaded the GPX file for a walk from Tideswell to pc, copied it to device using drag and drop, import and copying directly to SD card via card reader. In all three instances the file is visible in satsync (latest version) but not visible on device.
I have found previously that renaming gpx files on the pc has no effect when re-loaded onto device, so I conclude that there must be a "header" in the gpx that is required to be visible on the Satmap. |
Posted: Fri Aug 01, 2008 12:09 pm Post subject: |
4ndynorfolk wrote: |
Just tried the same route (tideswell) and its all fine on my unit! Used the "import" and saved to internal memory.
Obvious question but have you unplugged from USB and turned A10 off then on....?
Jason |
Posted: Fri Aug 01, 2008 3:41 pm Post subject: |
Thanks for the advice Fatchef.
Worked this time.
Interestingly, the file is called 151.gpx when downloaded, appears as 151.map in satsync and route 0001 on the Satmap. |
