jimelliot Occasional Visitor
Posted: Fri Jul 18, 2008 9:20 pm Post subject: Problem with TT930 speed warning |
I have my TT930 set to sound an alarm when I go over the spped limit. This has been working OK until recently. Sometimes when I over the speed limit, the warning seems to lock up, and the display shows actual speed as a number and the speed limit as 39 mph. These numbers lock up and don't respond once this happens until I have reduced my speed to below 39 mph. The warning sound also stops.
Once i reduce my speed to below where it locks up, it starts operating normally again.
Anybody else experience this problem and is there a fix?
TIA |
nitr0genics Occasional Visitor
Posted: Fri Jul 18, 2008 11:25 pm Post subject: |
what navcore are you running and have you updated via tthome to the latest version? |
Posted: Sat Jul 19, 2008 4:56 am Post subject: |
what's navcore? |
Posted: Sat Jul 19, 2008 8:37 am Post subject: |
Navcore is the name of the software running on your device, to find out the version number tap the sat strength meter in the lower right corner, the version is displayed on the right side of the resultant display - Mike |
Posted: Sat Jul 19, 2008 9:14 am Post subject: |
8.010 |
Posted: Sat Jul 19, 2008 9:43 am Post subject: |
You have the latest version on the device, as it is showing a limit of 39 this is either a road you have altered the speed limit on using Map Share or another user has done this.
The stupid software cannot use true UK MPH limits, instead it rounds up/ down using KPH values - this messes up the map data and untill they soft this bug out I wouldn't alter any road speeds in the UK or it will mess up your map - Mike |
