IanHibbert Occasional Visitor
Posted: Fri Jul 18, 2008 1:02 am Post subject: |
Presumably, existing routes are not wiped clean by the upgrade.....?! |
J-K Occasional Visitor
Posted: Fri Jul 18, 2008 1:12 am Post subject: |
IanHibbert wrote: | Presumably, existing routes are not wiped clean by the upgrade.....?! |
No they weren't, but I expected them to be because I did a default setting. One would expect that to reset everything. |
FrequentFlyer Lifetime Member
Posted: Fri Jul 18, 2008 9:53 am Post subject: |
Where do you pick up the time.....in one of the 2/4 info boxes only ? |
Posted: Fri Jul 18, 2008 10:18 am Post subject: |
FrequentFlyer wrote: | Where do you pick up the time.....in one of the 2/4 info boxes only ? |
Yes, from those. It's showing 10.53 at the moment which could be believable. Only it's just coming up to 10.20. |
Posted: Fri Jul 18, 2008 11:03 am Post subject: |
But you posted at 09.18 ?!
Just noticed...I'm also an hour behind......I assume that PGPS hasn't caught up with Summer yet. |
Posted: Fri Jul 18, 2008 12:57 pm Post subject: |
I've e-mailed SatMap about this clock issue and will report back. I do feel that if the clock was kept running when the device was turned off it would reacquire a fix very much faster. Let's hope it does have a realtime clock to make this achievable!
Just been checking adverts for SatMap and it is clearly advertised by SatMap as having:
Full GPS functionality (real time clock, logging waypoints, time etc)
So making the clock work would seem a necessity for the unit to work as described. |
robs1972 Frequent Visitor
Posted: Fri Jul 18, 2008 6:06 pm Post subject: |
I had a few issues with the clock a couple of weeks after buying it.....it was about 7 hours out on one occasion....the best thing to do is not start trying to chase the correct time by using the offset function....keep the offset as it should be and the time corrects itself during the ride. _________________ I like mapping, I like mapping, I like mapping and I like to map! |
djhpk Occasional Visitor
Posted: Fri Jul 18, 2008 6:44 pm Post subject: Satmap release v1.2 System Software |
Well, I have never seen a problem with the Active 10's time, once a lock has been achieved. This through software versions 1.03, 1.16 and now 1.2 (serial number 700296). |
Posted: Fri Jul 18, 2008 9:16 pm Post subject: |
Agreed, but if it has a real time clock as it is advertised as having, it should know the time the moment it is turned on (unless the battery has run down or been removed.)
Other GPS's (eg Garmin) remember the time so do not waste valuable minutes obtaining it so that they can get on immediately getting a position fix. These GPS's do take a while to get their initial fix (like the SatMap) but on subsequent startups they get a fix much quicker unless they have moved a considerable distance since last used. The SatMap seems to start from scratch every time even if it was last used just a second ago. Why does its real time clock fail to remember the time!?
This is particularly inconvenient of you accidentally turn it off instead of pressing the brightness button (easy to do.) You then have to wait a pretty long while for it to get going again. If it remembered the time the delay would be minimal. |
Posted: Fri Jul 18, 2008 9:33 pm Post subject: |
Not sure whether this means anything, but I've just altered one of the 4 boxes for the first time to show the time, and it is exactly as per the PC....(is that where it came from, as the USB cable is plugged in ?). But, it has yet to lock on as I'm deep indoors. |
Posted: Fri Jul 18, 2008 9:43 pm Post subject: |
FrequentFlyer wrote: | Not sure whether this means anything, but I've just altered one of the 4 boxes for the first time to show the time, and it is exactly as per the PC....(is that where it came from, as the USB cable is plugged in ?). But, it has yet to lock on as I'm deep indoors. |
I've just tried that and mine shows 12:57 where as I write it's 21:39.
Try turning it off, then back on again and see what time you have then. If it does show the true time you do have a real time clock; perhaps it could be a different hardware revision or my clock is faulty. |
Posted: Fri Jul 18, 2008 9:54 pm Post subject: |
OK, powered off...unplugged USB...power backup....time ? Again, exactly as the PC, (for easy reference,) 21.54.
ps Just checked 'Power Offset'...and it says 'No time offset.' |
Posted: Fri Jul 18, 2008 10:37 pm Post subject: |
Oddly, I'd left mine plugged in the USB for a while and when I came back it now shows the correct time! Whether it's got that from the PC or a satellite I don't know.
However I unplugged it, turned it off and back on again right away. The time had shot up an hour to 23:30.
Then I turned it off and on again. The time was now showing as 00:31. It had jumped another hour.
Predictably now, turned it off an on once more. Another hour jump to 01:33.
Looks like a software issue (it's on v1.20).
My time offset is Plus 1 hour. |
lucevans Frequent Visitor
Joined: Mar 21, 2007 Posts: 261 Location: Cambridgeshire, UK
Posted: Sat Jul 19, 2008 3:57 pm Post subject: |
I've upgraded to v1.200 and my unit does the same thing - i.e. advance the time by 1 hour every time the unit is powered-on.
After a bit more tinkering-around, it appears that this issue corrects itself *if* (and only if) the unit takes more than a few seconds to re-acquire satellites on power-up. In practice, this would be if the unit has moved a significant distance since it was last powered on, or if a significant length of time has passed since it was last powered on. In either of these cases, the incorrect, shifted time is displayed until satellite lock is reacquired, then the clock display jumps back to the correct time.
However, if the unit is powered off only briefly, then turned back on, satellite acquisition is near-instantaneous, and the clock does *NOT* correct itself. In this case, I've had some success by disconnecting the LiPol battery for 60 seconds before reconnecting and powering up. This seems to delay satellite reacquisition by just long enough to cause the clock to be corrected.
Satmap really must come up with a fix for this quickly - it has the potential to mislead users in a navigation setting, and that could be dangerous. |
Posted: Sat Jul 19, 2008 4:57 pm Post subject: |
Indeed it could be very dangerous. Glad I'm not the only one to have this though. If SatMap cannot get this fixed this week they need to make an ealier release available for download as an interim measure. |
