Pocket GPS World :: View topic - Ford Focus Sat Nav
Ford Focus Sat Nav
chrisphelan
PostPosted: Fri Jul 18, 2008 3:10 pm    Post subject: Ford Focus Sat Nav Reply with quote
i recently purchased a 2008 ford focus with built in Blaupunkt Sat nav & SD Card slot. I have transferred the map data onto the SD card which works fine but would now like to add the speed camera files. The problem is I'm unsure what type of speed camera file i need to download & which file on the SD card i need to install it into. Any help would be grately appreciated, Thanks.
PaulB2005
PostPosted: Fri Jul 18, 2008 3:19 pm    Post subject: Reply with quote
Hi and welcome.
Do you know if the unit has a model number?
Do you know if it supports 3rd party POI (Points Of Interest)?
Only a few built in car Sat Navs actually support adding the database (BMW / Mini springs to mind) to them and the ones that do just display the icon and give no warnings. However with a bit more info we might be able to help.
PostPosted: Fri Jul 18, 2008 3:25 pm    Post subject: Reply with quote
this has been asked a few times before... (I used Search - for "blaupunkt" to find them), but it doesn't look too hopeful.
THIS ONE seemed to be the best reply, as it mentions the manual, but apparently there is no mention of "custom POIs" or "user POIs" which is what you need to be able to add the database from here (or anywhere else for that matter).
22.094 (25 Sep 24)
