pem1 Occasional Visitor
stevieboy308 Occasional Visitor
Posted: Mon Feb 11, 2008 12:14 am Post subject: |
hi all,
can anyone give me (an idiot!) an idiot guide on what program i need to open the files please.
cheers stevie |
Posted: Mon Feb 11, 2008 8:36 pm Post subject: |
winrar m8 just google for it |
BodgerBaz Lifetime Member
Joined: Jun 12, 2005 Posts: 368 Location: Mörsdorf, Germany
Posted: Wed Feb 13, 2008 8:32 am Post subject: |
Newer versions of Winzip will also open them. |
Stecha Regular Visitor
Posted: Sat May 31, 2008 8:48 pm Post subject: |
Those are useful links, but, I have found today that the Industrial Estates file will not unzip properly. It unzips the image but not the locations. |
Posted: Sun Jun 01, 2008 8:48 am Post subject: |
Either try again or send me a PM with your email address and I'll email it to you. The file contains both OV2 and CSV files - which one do you want? |
Posted: Mon Jun 02, 2008 11:18 am Post subject: |
BodgerBaz wrote: | Hi,
Thanks Baz, pm on its way. |
Posted: Mon Jun 02, 2008 2:50 pm Post subject: |
Stecha wrote: | BodgerBaz wrote: | Hi,
Thanks for that, PM with attachment on it's way. |
Posted: Mon Jun 02, 2008 10:26 pm Post subject: |
BodgerBaz wrote: | Stecha wrote: | BodgerBaz wrote: | Hi,
Thank you again kind sir. I have received the attachment OK, but have had not had time to install. |
gixerste Occasional Visitor
Posted: Tue Jun 10, 2008 4:03 pm Post subject: Re: hgv stuff for tomtom |
Ok first off hi i'm a complete newbie to forum and HGV driving i have a tom tom one v3 will the stuff above work? mainly need low bridges/widths and weight limits cheers in advance |
Posted: Sat Jun 14, 2008 8:23 am Post subject: |
Yes it will.
1. Download file
2. Unzip the file and choose your bridge height (for instance 10'6") the 'set' will be in 3 parts:-
‘Bridge 10’6.OV2‘ which is the bridge locations.
‘Bridge 10’6.BMP’ which is the little icon which will appear in your satnav.
‘Bridge 10’6.OGG‘ which is the warning sound.
3. Attach your satnav device to your PC or better still, insert your SD card into the PC. Whichever way you decide to do it you need to copy the three files above to the map folder on your SD card.
4. Now start your TomTom and touch the main map screen.
5. Select Change Preferences then Manage POIs (on screen 2 of 7).
6. Select Warn when near POI.
7. Navigate until you find the ‘Bridge 10’6’ POI (or whatever height you picked).
8. I have mine set for 5 miles (so I can take an alternative route in time) so have set the distance to 8800 yards.
9. Click YES when it says “Is this the sound you want?”.
10. Tick the box to accept the Warn only if POI is on route.
Go look for a bridge and try it - carefully :-) |
tom9851 Frequent Visitor
Joined: Feb 14, 2004 Posts: 283 Location: Warrington, Cheshire.
Posted: Sun Jul 06, 2008 2:00 pm Post subject: |
Does this freebie poi for low bridges have the same data as the poi being offered by lowbridges.com - they charge 9.95 - I don't mind paying for it as long as it's kosher - I currently just use the AA Trucker's Atlas which I think has about 1600 bridges listed but as you know they are mostly on major roads - the lowbridges.com site says they're poi has over 3000 bridges listed - I still use TomTom V3 (bit of a dinosaur I know!) and assume both these poi's will work ok with it?
Grateful for any info on this
Tom _________________ ___________
IPAQ2210/ROM-1.10/LEXAR 32X 256MB SD/Kingston ElitePro 1GB CF
TTN3-V3.03/Wired GPS-V3.03/Globalsat BT-338 |
Posted: Sun Jul 06, 2008 3:20 pm Post subject: |
The freebie set has 3,069 bridges listed with the highest one being 17'-9". Some are listed as '???' so you won't know what the height is until you see the road sign? |
Posted: Thu Jul 17, 2008 10:10 pm Post subject: Re: hgv stuff for tomtom |
Is this site run by anyone on here ?
I have two or three corrections from my locality to pass on if interested. |
mpwilson99 Lifetime Member
Joined: Jun 30, 2007 Posts: 462 Location: Hickstead, Sussex
Posted: Sun Jul 20, 2008 9:01 pm Post subject: |
I would be interested to know what ones you have amendments for...
If you want, post me the locations of the bridges and i will see what i have for them!
MPW |
