Pocket GPS World :: View topic - Navman 4410 Bluetooth GPS- Is it any good?
buckrogers
PostPosted: Fri May 21, 2004 2:20 am    Post subject: Navman 4410 Bluetooth GPS- Is it any good? Reply with quote
It would be nice to hear the pros & cons from anyone who is familiar with it.
So far I've used the icn630 V2 (Quite Good) & TTN3 BT (Not so good)
Just looking for an incremental improvement in navigation.
Tim Buxton
PostPosted: Fri May 21, 2004 9:16 am    Post subject: Reply with quote
Since the 4410 and iCN use similar software and the same maps, I wouldn't think there would be much difference between them from a routing point of view.
Tim
risky3301
PostPosted: Fri May 21, 2004 5:44 pm    Post subject: Reply with quote
I use a Navman 4410 Bluetooth, with XDA II, I think it's excellent, battery life of 4410 exceed my expectations, I've used the system and software Smart ST maps in the UK, Belguim, France and Spain, only 2 times when I went wrong, one was the POI fault, hotel I was travelling to was incorrectly addressed in the POI and the 2nd time was when I ignored an instruction because I thought I knew best and of course I didn't. I've not used the items you mentioned so I can compare and which is best, I doubt you will find better than the NAVMAN 4410
Genie
PostPosted: Fri May 21, 2004 7:29 pm    Post subject: Reply with quote
I would also highly recommend the Navman 4410.
I too was amazed at the battery life (although it does not have a rechargeable battery - 3 AAA's).
I can't comment on the software as I use TomTom software with the Navman hardware (4100 is same hardware as 4410)
I've seen the Medion system that my friend bought from Aldi over a week ago, and I can see why mines far superior.
Ipaq 4150, Polstar PBT-111, TomTom3, Kingston 256mb SD, Arkon Powered Amplified PDA Mount
icsys
PostPosted: Fri May 21, 2004 10:33 pm    Post subject: Reply with quote
If you are referring to the receiver (4100) then I would give it 10/10 for performance. Even when placed out of view of the sky!
I managed around 15 hours on a new set of AAAs Thumbs Up
As for the software then as Tim said it is probably much the same as the iCN
Ian.
iPAQ 2210 | Navman 4100 BT Receiver
Navman iCN 635
TomTom GO
Anquet OS mapping
22.105 (30 Oct 24)
