Pocket GPS World :: View topic - Favorites file
Favorites file
Nigel42
PostPosted: Sat Jun 28, 2008 12:45 am    Post subject: Favorites file Reply with quote
I've saved my favs (after a back up) but cant find the folder where they are hiddden.
Im using a mac!
thanks
dhn
PostPosted: Sat Jun 28, 2008 12:49 am    Post subject: Reply with quote
Favourites are kept in a FILE called mapsettings.cfg that resides in the map folder.
PostPosted: Sat Jun 28, 2008 12:53 pm    Post subject: Reply with quote
Strictly speaking it's "MapSettings.cfg" Smile
Upper and lower case don't matter in Windows, but do in Linux which the TT uses.
dhn
PostPosted: Sat Jun 28, 2008 12:58 pm    Post subject: Reply with quote
Thanks for the correction, Andy. I'm getting careless ... Embarassed
sven1
PostPosted: Tue Jul 01, 2008 5:25 pm    Post subject: Reply with quote
just taken my 920t back to factory settings (copied over before I used it). took a copy of current config before I did it and would now like to put my favourites back but there is no mapsettings.cfg file in my map folder!
PostPosted: Tue Jul 01, 2008 5:33 pm    Post subject: Reply with quote
It is re-created when you use the Map for the first time.
sven1
PostPosted: Tue Jul 01, 2008 5:36 pm    Post subject: Reply with quote
thanks but how then can I get it back from the configuration I saved before taking it back to factory settings?
Jon
PostPosted: Tue Jul 01, 2008 5:39 pm    Post subject: Reply with quote
Do you mean you can't find it in the map folder on the machine, or the one on your backup?
Are you looking in the NAMED map folder? (ie "Western Europe" or something like that not a folder called "maps")
sven1
PostPosted: Tue Jul 01, 2008 5:41 pm    Post subject: Reply with quote
yep, looking in western europ map folder in the backup on my HD I did before copying all the original files on to the device
Ah, you mean that there is no cfg File in your Backup Map Folder! Embarassed
Are you looking in the right Backup, if you have more than one?
It is an Explorer Backup, isn't it?
sven1
PostPosted: Tue Jul 01, 2008 5:43 pm    Post subject: Reply with quote
explorer backup. one i did this morning with all the new maps (720) on it. mind you, I hadn't used it since updating the maps so maybe my favourites might not have been recreated post map upgrade? might that be the issue?
PostPosted: Tue Jul 01, 2008 5:47 pm    Post subject: Reply with quote
It could be. Have you a Backup of your previous Map?
If so try copying that to the new Map, to see if it works.
I believe doing this has had mixed success, but it might work.
sven1
PostPosted: Tue Jul 01, 2008 5:54 pm    Post subject: Reply with quote
only got factory setting and the 720 maps one i did this morning. never mind. I only had a few anyway.
Jon
22.063 (19 Jun 24)
