Pocket GPS World :: View topic - Hypothetical map question
Goto page Previous  1, 2, 3
theripper
PostPosted: Fri Jun 27, 2008 8:46 pm    Post subject: Reply with quote
[/quote]
Again, I' afraid that "I don't know" is the honest answer. In HOME you get the option to delete all your own corrections, all your downloaded corrections or both sets. Whether that means a TomTom correction would never overwrite one of your own I've no idea, but I wouldn't put it past them! I will endeavour to find out, though.
Of course, using the TomTom corrections might put restrictions in place which are not really there. I've seen some reports of such instances elsewhere.
Edited to add:- Of course, if the changes you make are purely for your own benefit, you should not share those changes as there is a chance that they may be incorporated into future map releases![/quote]
This is what I was wondering about, there is a road in Southampton with a low bridge which obviously is available for other people but not for the lorry and if I block that road on my map I would not want that sent to mapshare but other peoples corrections could be useful.
theripper
theripper
PostPosted: Tue Jan 06, 2009 11:00 pm    Post subject: Reply with quote
theripper wrote:
Another question for you Tim-
I am thinking about buying a 530 with UK mapping
Would it be possible to have 2 copies of the same map on one unit so that I can make map corrections on one without affecting the other ie roads that I can't take lorries down (low bridges etc).
theripper
Tim
Following on from the question above I splashed out in December on a 520 and it works a treat - What I have done is transfer everything from the internal memory to an SD card and set it up for my car with a car icon etc, and copied the same again to another card and set it up for larger vehicles that I may drive(blocking roads that I know I can't use etc) but
If I use the one for the car and then turn the unit off and insert the other card for the lorry the icon has reverted to the blue arrow so I change it to a lorry - then when I have finished I replace the card for the car and that has also reverted to the blue arrow. As far as I can make out there is nothing on the internal memory so they are running from the cards. Any idea what could be happening, it's not a major problem just annoying that I cant sort it out.
theripper
theripper
PostPosted: Tue Jan 06, 2009 11:53 pm    Post subject: Reply with quote
theripper
Tim or anybody who can help!
theripper
Page 3 of 3
22.054 (22 May 24)
