Pocket GPS World :: View topic - :wink: Did You Know ...
Goto page Previous  1, 2
PostPosted: Fri Jun 27, 2008 2:08 am    Post subject: Reply with quote
Voltage supplied on on a USB port is a defined simple standard - 5V.
Current capacity is slightly more complicated.
The USB spec. says that a receiving device must first connect in a low-power mode (drawing 100 mA maximum) and state how much current they need, before switching, with the host's permission, into high-power mode up to a maximum of 500mA.
Mains and car chargers are not intelligent hosts and are also deliberately designed to be able to supply more current than this, which will help to charge the battery quicker.
So on balance I reckon "rtj70" wins... Cool
The method by which the devices recognise when they are connected to a dumb charger rather than a PC, is not as well implemented as it could be. The car charger for my TomTom works fine , but a Garmin Nuvi would often decide to go into computer link mode when it was connected to it. Pulling the cigar lighter plug out momentarily would sort it out, but pulling the USB plug out wouldn't.
PostPosted: Fri Jun 27, 2008 2:59 am    Post subject: Reply with quote
guys, you are all wrong. There is much more to USB charging than just the voltage.
1. Voltage : 5 V. UNIVERSAL
2. Amperage: a PC port provides 500 mA. Not enough for most devices. Good wall or lighter chargers provide 2 A, bad ones only 1 A or less
3. Data line signaling!!! As MaFt was mentioning sometimes the data lines are used to signal slow/fast charging.
In the worst case scenario (think iPAQ 310) you can ONLY use the vendor charger. All other USB chargers make it look like they charge the device but in reality they actually drain the battery. Read my review.
PostPosted: Fri Jun 27, 2008 3:17 am    Post subject: Reply with quote
I beg to differ!
First, what was wrong in my post, please?
And second, you say "a PC port provides 500 mA." (true, as I said) "Not enough for most devices" - Surely an over generalisation. I'd have thought my TT720 with it's screen on full brightness would have one of the larger current requirements, but it still manages to charge (slowly) from a standard PC USB port.
Strawbs
PostPosted: Fri Jun 27, 2008 3:27 am    Post subject: Reply with quote
Laughing
I really didn't expect this much debate about a Motorola mains charger working with a TT. Just thought I'd post a money saving tip.
Laughing
iPhone 12 Pro
Strawbs
PostPosted: Fri Jun 27, 2008 3:35 am    Post subject: Reply with quote
Andy_P wrote:
I beg to differ!
Andy: my post was meant to be discussing mains mini-usb chargers - it diversified to include PC ports because of what I believe was a misunderstanding. I'm going to edit my original post now to save any further confusion.
but carry on guys, this is interesting - I'll get some popcorn. Laughing
iPhone 12 Pro
Floriank
PostPosted: Fri Jun 27, 2008 10:58 am    Post subject: Reply with quote
Yawn......... Wink
rtj70
PostPosted: Fri Jun 27, 2008 12:22 pm    Post subject: Reply with quote
When my TomTom 720 is plugged into my PC but not connected to home it shows up as a single USB mass storage device using 500mA. If I connect, because of the memory card it appears as 2 such devices each taking 500mA.
Since 500mA is all the port will provide then it is enough for a TomTom 720 to charge/run. The same power is drawn/used by my iPod Touch.
Strawbs
PostPosted: Fri Jun 27, 2008 12:31 pm    Post subject: Reply with quote
and when your TT 720 is plugged into the mains?
iPhone 12 Pro
rtj70
PostPosted: Fri Jun 27, 2008 12:34 pm    Post subject: Reply with quote
"and when your TT 720 is plugged into the mains?"
No idea because (a) I do not have a mains charger nor need one and (b) I do not have anything to measure current draw for any of my electrical items in the house.
franb
Banned
PostPosted: Fri Jun 27, 2008 1:51 pm    Post subject: Reply with quote
Just my two penn'orth.
Doesn't matter what current it provides (assuming it's sufficient) as the device (any) will ONLY draw what it needs; not the max available.
PostPosted: Fri Jun 27, 2008 2:31 pm    Post subject: Reply with quote
True, but if the max available is 500 mA, and the charging circuit could handle 1.5A this basically means it takes you at least three times as long to charge the battery as would be needed.
And before you repeat my mistake - I had a "1 A" USB car charger connected to two devices , a GO910 and a One XL (via Y-cable). The charger worked for a while, then blew up, delivering straight 12 V to both devices. Both motherboards had to be exchanged.
Andy_P wrote:
I beg to differ!
true, but I liked the theatralic sound of my statement. Shocked
Trevor1234
PostPosted: Fri Jun 27, 2008 4:14 pm    Post subject: Reply with quote
Hi Strawbs
Now you can see how easy it is to start a war.
Tomtom Go 720.
Navcore 9.510
GPS World Traffic cameras
Home 2.7
iPhone 3G
Strawbs
PostPosted: Fri Jun 27, 2008 4:20 pm    Post subject: Reply with quote
Trevor1234 wrote:
Hi Strawbs
A bit of verbal jousting never hurt anyone, but I was just trying to help - honest. Shocked
iPhone 12 Pro
Trevor1234
PostPosted: Fri Jun 27, 2008 4:34 pm    Post subject: Reply with quote
Hi Strawbs
A Archduke Ferdinand went out for a peacefull drive in 1914. A chap stepped out as he drove past and shot him. That’s how WW1 started. If Archduke Ferdinand had stayed at home the war would never have began. So, it was his fault.
And yours.
Tomtom Go 720.
Navcore 9.510
Home 2.7
iPhone 3G
Pocketgps
PostPosted: Fri Jun 27, 2008 5:08 pm    Post subject: Reply with quote
Using a pc to charge your device via the usb lead will actually make the battery last a lot longer (30-40% in my experience). The lower charge current that the pc provides is better than fast charging the battery.
I have bought over 70 batteries for my rc cars, planes, helicopters over the last 20 years or more from NiCD, NiMH to the lastest LiPo.
Slow charging is always best if most boring.
The LiPo's I treat with much respect costing £60-80 a time.
Page 2 of 2
