Pocket GPS World :: View topic - TT 520 Personal Settings Problem And Windows Explorer
fluke9
PostPosted: Thu Jun 26, 2008 4:48 pm    Post subject: TT 520 Personal Settings Problem And Windows Explorer Reply with quote
When I back up using windows explorer, once I write all info back to the TT 520 it never remembers the settings, compass, POI warning sounds, Keyboard and Status Bar preferences Planning preferences etc etc.
App 7.481
OS 3024
GPS 1.21
Boot 5.4106
Map UK+IRL 720.1802
Any idea's ???
TTGO730
App 8.351 (9982/090518) OS:315187
GPS v1.20, Boot 5.5120
Map WCE 845.2645
iPhone 4S 3 (Contract)
Dave.
PostPosted: Thu Jun 26, 2008 4:55 pm    Post subject: Reply with quote
Check the properties of "MapSettings.cfg"
Has it got set to read only or some other odd setting?
Sounds like it isn't being read properly, so a new one is being created when it first boots.
You can check the file creation dates to see if that's what is happening
fluke9
PostPosted: Thu Jun 26, 2008 5:16 pm    Post subject: Reply with quote
No funny settings, but the date in the back up is the date I backed it up ???
So not sure what's going on there then.
TTGO730
Map WCE 845.2645
Dave.
dhn
PostPosted: Thu Jun 26, 2008 5:31 pm    Post subject: Reply with quote
You may want to try the Clear Flash tool from here:
http://www.tomtom.com/support/index.php?FID=6211&Lid=4&nostat=1
I don't think it'll help for the situation you described but it shouldn't hurt.
PostPosted: Thu Jun 26, 2008 5:39 pm    Post subject: Reply with quote
What MIGHT be happening....
The TomToms have a habit of losing their settings. We've never quite got a handle of exactly what causes it, but it definitely seems to happen more often when you either connect to the PC or connect to Home.
When it happens, a new MapSettings file gets created automatically.
Maybe you've just been unlucky and this is happening just before you make the backup.
Is it repeatable? You might need to try some experiments.
Having said that though.... I don't think Keyboard and Status Bar preferences etc are stored in MapSettings.cfg, so it might be something more global if SEVERAL settings files are going wrong.
fluke9
PostPosted: Thu Jun 26, 2008 5:43 pm    Post subject: Reply with quote
It has only happened twice, both times I reverted back to a back up I made prior to a new App being installed.
TTGO730
Map WCE 845.2645
Dave.
PostPosted: Fri Jun 27, 2008 1:27 am    Post subject: Reply with quote
Ah, that's not the same as you said in post #1! You said "When I back up using windows explorer.....it never remembers the settings"
If you install new software it's quite likely to reset a lot of stuff. I just
accept that as a fact of life!
fluke9
PostPosted: Fri Jun 27, 2008 5:39 pm    Post subject: Reply with quote
But I would have assumed if I backed up prior to the latest App being installed which was 8.1??? replacing the back up should put everything back as it was, wouldn't it ???
TTGO730
Map WCE 845.2645
Dave.
PostPosted: Fri Jun 27, 2008 9:41 pm    Post subject: Reply with quote
Agreed.... Smile
Also I now realise that some of the things you are saying have reset are NOT in MapSettings.cfg
I've just had the same problem!
