Pocket GPS World :: View topic - Updating TT720 to Navcore 8.0010
pah007
PostPosted: Wed Jun 25, 2008 10:20 am    Post subject: Updating TT720 to Navcore 8.0010 Reply with quote
Whenever i try to update my TT720 via the latest version of TomTom Home, although it offers updates to Quickfix and mapshare items, it does not offer to update to Navcore 8.0010
I am currently on previous version, which from memory i think is 7.481
Is there anything i need to be doing to get it?
Paul
Wazza_G
PostPosted: Wed Jun 25, 2008 11:14 am    Post subject: Reply with quote
The way I got my 720 to update to v8.010 was to go via HOME and delete the application from the SD card and then disconnect, reconnect and get it to do an update, that worked for me.
But do remember to do a backup before you do anything.
Good Luck.
Daggers
PostPosted: Wed Jun 25, 2008 12:03 pm    Post subject: Reply with quote
I think you need to be absolutely certain of the version that is currently on your TT720. From memory, it could only be upgraded to v8.010 if it was already at the previous latest version. v7.481 should be the right one, but it may help if you could double check this.
And of course, check it on the TT itself. not via TTHome which is known to misreport version numbers!
pah007
PostPosted: Wed Jun 25, 2008 12:23 pm    Post subject: Reply with quote
The only items on the SD card are i think a couple of small files which might be related to logo's
The version on the TT720 is 7.481 (seen from the TT itself, not via Home) which i upgraded to back in May.
This was offered as an upgrade from 7.221 but it is now not offering me the upgrade to v8
PostPosted: Wed Jun 25, 2008 4:13 pm    Post subject: Reply with quote
Tried Wazza's suggestion?
PaulBt
PostPosted: Wed Jun 25, 2008 11:06 pm    Post subject: Reply with quote
Which application should be removed from the SD card?
The SD card is optional on the 720.
TT720 V8.010, regular audio book user.
WestEuro v805 connected to E90 on O2
TT910 V6.525, TTN5, TTN3, TT on Psion 5mx
PostPosted: Wed Jun 25, 2008 11:57 pm    Post subject: Reply with quote
I guess he was using an SD to boot from for some reason, but the principle is the same.
From whichever location you are getting the TT to boot from, remove all the LOOSE files, i.e. the ones that are not in any folders (leave the folders alone). This will force Home to re-install from the version it has cached on your PC.
If you think THAT mat be corrupt, remove it from Home's 'downloads' folder, and that will force Home to re-download it.
PaulBt
PostPosted: Thu Jun 26, 2008 6:48 am    Post subject: Reply with quote
thanks Andy.
It makes sense to me now Wink
Obviously this is fairly drastic, and requires complete trust in the Home application...
So take a backup
Paul
PostPosted: Thu Jun 26, 2008 10:59 am    Post subject: Reply with quote
So take a backup
You're wise to be cautious!
Backup with Win. Explorer
And we can always get you going with a manual install of the files from a slightly older software version if Home did mess up.
pah007
PostPosted: Thu Jun 26, 2008 12:46 pm    Post subject: Reply with quote
Today for some reason after only removing the SD card which only had a couple of small logo files i was offered the upgrade to v8 which went successfully
22.105 (30 Oct 24)
