Pocket GPS World :: View topic - TT720 Help. I am out of ideas!!
Goto page Previous  1, 2
audirob
PostPosted: Tue Jun 24, 2008 7:31 pm    Post subject: Reply with quote
I dont have a SD card.
I have deleted the loose files and updated and still the same problem.
I am going to buy a SD card then i will install on there and hopefully will be back on track.
Honestly I wish i never updated, I backed up and I cant understand why it will not revet back.
PostPosted: Tue Jun 24, 2008 7:44 pm    Post subject: Reply with quote
audirob wrote:
I have formated the card and reinstalled everything as it was. via explorer
Not working!
I formated the card and updated from tomtom home
Not working!
I Formated the card and installed a V7 backup i have still not working!
If you don't have a card I can only assume your earlier post was refering to formatting the internal Flash Memory?
One other trick you could try is the "Clear Flash" tool, it claims to be for map activation problems but it has been used to cure some other faults, have a read of This Page - Mike
audirob
PostPosted: Tue Jun 24, 2008 8:16 pm    Post subject: Reply with quote
Yes sorry, formatting the internal mem,
That clear flash only works if you have a sd card.
I might be thick but i cant figure it out.
Had enough now, i am off to another pc now to format the hard drive one last time.
Then restore again and if it still dont work............... slit my wrists!!
john877
PostPosted: Tue Jun 24, 2008 8:21 pm    Post subject: Reply with quote
As Mike has said try the clear flash tool !! also when you have deleted the loose files when you connect to Tomtom home and if you are not offered any updates do you click on add maps voices etc ??If you can see the application update select it and add !! make sure you disconnect your device by the disconnect tab
If you stick in there with Mike and Andy _P I am sure you will get it sorted
audirob
PostPosted: Tue Jun 24, 2008 10:45 pm    Post subject: Reply with quote
Done a format with a win xp computer and reinstalled everything, and not had a crash yet after 20 mins of playing.
I will update tomz.
Page 2 of 2
22.064 (26 Jun 24)
