MickeyM Lifetime Member
Joined: May 12, 2005 Posts: 216 Location: Norfolk UK.
Posted: Mon Jun 23, 2008 8:10 pm Post subject: Manufacturer Refurbished Tomtom 910 |
Is a Manufacturer Refurbished Tomtom 910 a good buy from Total PDA, for £150. Also do I get a discount from them if I am a subscriber to Pocket GPS World. Thanks. |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10643 Location: Suffolk, UK
Posted: Mon Jun 23, 2008 8:17 pm Post subject: |
It's a good buy, but I don't think any PND Device will qualify for a Discount because of the low margins that they run at.
Nothing to stop you asking though. _________________ Richard
TT Via 135 App 12.075: Europe Map v1135 |
GPS_fan Pocket GPS Moderator
Joined: Jan 04, 2007 Posts: 2789 Location: Hampshire, UK
Posted: Mon Jun 23, 2008 8:57 pm Post subject: |
Factory refurbished items are often better than new, because they may undergo additional testing to ensure that any fault has been rectified.
Although you might not get discount as such, you might get free P&P or something to bring the price down - but this is obviously at the discretion of the retailer.
It might also be worth checking the warranty period of the refurbished unit and making sure that you're happy with that, compared with what you would gain for a new unit with manufacturer's warranty (if they're different). _________________ Andy
PocketGPSWorld.com supports Help for Heroes - Read here |
Posted: Mon Jun 23, 2008 10:22 pm Post subject: |
I would ask them to confirm what maps are installed to this prior to purchase as this could become costly, if the maps are way out of date then a new 720, 920 or even the 730, 930 could be less costly in the long run.
The 910 comes with Europe and US mapping do you need this? - it also has a mount that is known to be troublesome although I didn't have many problems with mine - many others did.
A hard drive in a PNA is also questionable, heat, vibration etc in a car doesn't do these type of drives much good.
If you want the latest mapping and only want to spend around the £150 to £200 I would look at the x20/ x30 units, the 910 is a very capable device - but check the maps before spending the cash, as for warranty the 910 was supplied with a two year cover, newer x20/ x30 units only get 12 months, a re-con 910 would get 6 months - Mike |
Posted: Tue Jun 24, 2008 2:36 pm Post subject: Manufacturer Refurbished Tomtom 910 |
Well, 910 arrived this morning,looks new. But so far I have had to reset it 5 times, also cannot get it to snap into the docking station, but it will work by sitting just on it. It has Ver:6.525 firmware, and Map ver:660.1219.
Any idears why I have to keep resetting, and why it will not snap hold on the docking station. If I can get over those two problems I will be very pleased with the unit. Regards Mike. |
Andy_P Pocket GPS Moderator
Posted: Tue Jun 24, 2008 2:48 pm Post subject: |
Rather than wasting time trying to work out why it is resetting, you could try just updating to v7 software, as your v6 is very old. That is quite likely to sort out the reset problem as well.
First things first though. Have you done the all-important Windows Explorer backup yet? DO IT NOW before anything else.
And I've never had an x10 model myself, but I seem to remember that they were only supposed to sit loosely in the dock, they didn't "snap in". |
Posted: Tue Jun 24, 2008 3:24 pm Post subject: |
They sit on the Desktop Mount, but snap on to the Windscreen Mount. _________________ Richard
Posted: Tue Jun 24, 2008 5:37 pm Post subject: |
The outer ring on the windscreen mount that you rotate has two distinct locked positions, as you hear the first click that locks the mounting arm, the second click is the fully secured position. It can take considerable force to rotate the ring to the second position but once done the device should lock to the mount (otherwise the release button on the front of the device wouldn't be needed) - Mike |
Posted: Tue Jun 24, 2008 8:07 pm Post subject: Manufacturer Refurbished Tomtom 910 |
Hi Mike, Many thanks for the info, also Oldboy. Updated to 7.161, also done backup with IE. Looking good at the moment. Everything looks new except for maps, but they are newer than the one`s in my old GO VER:6.5 in that. Had hell of a job to find the reset, but so far so good. |
Posted: Tue Jun 24, 2008 8:53 pm Post subject: |
By the way Mike it comes with a 12 month manuf/warranty. |
