Pocket GPS World :: View topic - Lost Kate (computer voice not TV serial)
Nigel42
PostPosted: Wed Jun 04, 2008 8:17 am    Post subject: Lost Kate (computer voice not TV serial) Reply with quote
I seem to have lost Kate the computer voice. I still have the icon but no sound!
I have looked on TT home and cant find her voice to download!
Any ideas?
PostPosted: Wed Jun 04, 2008 9:21 am    Post subject: Reply with quote
What device have you got, if it is an x20 unit then the voices are on the CD that came with the unit, otherwise copy the files from your backup on the PC (if you don't have a backup this is a very good example as to why they are so important) - Mike
dsouter
PostPosted: Fri Jun 13, 2008 9:52 pm    Post subject: Re: Lost Kate (computer voice not TV serial) Reply with quote
Nigel42 wrote:
Vrtually every time I have operated my 920 in tomtom home I loseKate. When i dsconnect and restart device I get message saying selected voice (kate) is not available. When i tap next, lo and behold there she is and ready to talk. All support do is tell me how to reinstall voices. Yesterday home downloaded Kate as an update. but still it says she isn't there.
Calomax
PostPosted: Fri Jun 13, 2008 10:16 pm    Post subject: Reply with quote
Same thing happens to me on my 720 since upgrade to v8.010, although it happened on random occasions before. Mainly it seems to be after operating my Go with HOME. I use Tim for nav instructions and Kate for warnings etc. When I disconnect, I get the message that the voice selected is not available. Then the change voice screen comes up with Kate as the first option. I then have to scroll through to select Tim, then select Kate again as the computer voice.
Regardless of Support's advice, I think it's a bug which was there in version 7, and is worse in v8. It's an annoying niggle not a serious problem.
TT Go Essential
tanda
PostPosted: Sat Jun 14, 2008 10:45 am    Post subject: Reply with quote
Has anyone tried a 30 second press of the re-set botton, worth a try.
Audi A3 Sline sat nav
Calomax
PostPosted: Sat Jun 14, 2008 11:21 am    Post subject: Reply with quote
It's quicker & easier just to reselct the voice
TT Go Essential
lfbullitt
PostPosted: Sun Jun 15, 2008 3:19 pm    Post subject: Reply with quote
Ok, apart from "re-setting" the unit, what does a 30 second press do?Would you not lose anything that you have loaded onto the system by doing a factory re-set?
PostPosted: Sun Jun 15, 2008 3:23 pm    Post subject: Reply with quote
Pressing the reset button de-powers the device, the on/ off switch does not turn the power fully off. The restore factory defaults will lose some of your settings such as POI Warnings etc but it doesn't actually remove or delete anything from the device - Mike
Calomax
PostPosted: Sun Jun 15, 2008 10:25 pm    Post subject: Reply with quote
Does a 30 second reset mean holding the button in for 30 seconds, or waiting 30 seconds before turning on again? And does it do anything differnt to a short reset?
TT Go Essential
sinky50
PostPosted: Sat Jun 21, 2008 9:53 am    Post subject: Reply with quote
Hold reset button in for 30 secs
sinky50
maca2
PostPosted: Sat Jun 21, 2008 4:54 pm    Post subject: Reply with quote
I have the same thing happen on my new Go 730T but only when I use the Home software to control the unit, very odd.
So I have stopped controlling the unit via the home software.
PostPosted: Sat Jun 21, 2008 11:11 pm    Post subject: Reply with quote
I'll stick my neck out here and say that I believe "a reset is a reset".
So long as you hold it in long enough for the power to die completely (i.e. a second or two) then it makes no difference at all whether you hold it in for 5 seconds or 5 minutes.
Anyone got any proof to say different (and "advice" from TomTom support doesn't count! Laughing )
Calomax
PostPosted: Sun Jun 22, 2008 8:33 am    Post subject: Reply with quote
Andy, that's why I asked. I can't see what difference it can make once the device has powered off. But I did wonder if it made a difference if you turned it on immediately or if you waited a while.
I remember being told many years ago never to turn on a computer for at least 10 seconds after turning it off. That was before the days of Windows though when a computer didn't have to go through a shutting down process when it was turned off.
TT Go Essential
uffe73
PostPosted: Sun Jun 22, 2008 6:16 pm    Post subject: Re: Lost Kate (computer voice not TV serial) Reply with quote
Nigel42 wrote:
Any ideas?
Could it be that you have stored Kate's voice on a memory card? I had the exact same behaviour as you're describing before I tried changing the storage location to the main memory. I have one of my maps stored on the same memory card and that works fine, so I don't think it's the read speed of the SD card that is the issue. Maybe the trick is to use different storage locations for the map and the voice files. When I have time I will see what happens if I use the map stored in main memory and install a computer voice on the memory card. If that works, that would prove my theory.
[edit:] After a quick test I've arrived at the conclusion that the v8.010 application doesn't like the computer voices to be stored on a memory card. So, as long as the voice files are stored in main memory, they will work fine, regardless of where the map is stored. I wonder if this is something TomTom can fix in future bug fixes.
Regards, Ulf
TomTom GO720T: App ver 8.351(9982/090518), OS:315187, GPS v1.20, Boot 5.5120
TT RDS-TMC: 4V00.013
Maps: Scandinavia v840.2562, Western_Europe v715.1703
Garmin GPSMap 60CSx (SW ver. 3.70)
dsouter
PostPosted: Fri Jul 04, 2008 7:27 pm    Post subject: Reply with quote
Mad
Alas poor Kate your gone again
Lost for none to see
I hunt and hunt for I love you so
Please come back to me
Crying or Very sad
when you return to my pnd
I'll lock you in a vault
cos TomTom say
When I connect to home
my settings return to default (and thats when you get lost)
Rolling Eyes
But at least this time they are investigating!!!!!
Surprised
never mind eh!!!
go 1005
