cepheus1 Occasional Visitor
Joined: 06/07/2003 19:48:51 Posts: 18 Location: United Kingdom
Posted: Wed May 19, 2004 9:03 pm Post subject: TTN3, wired GPS and 2210 - Are there any problems? |
Hi!
I've been sitting on my upgrade because of all the problems people are reporting when using it with a 2210.
However, I am not using a bluetooth receiver so am I ok to load the software? Do I use 3.01 or 3.02?
Are all these problems purely associated with bluetooth and the 2210?
Thanks for your time in reading and thanks in anticipation of your assistance |
technik Lifetime Member
Joined: Mar 18, 2004 Posts: 789 Location: Midlands UK
Posted: Wed May 19, 2004 10:25 pm Post subject: |
I have a 2210 rom 1.10 and both wired and cf gps.
Never had any problems whatsoever.
It is only bluetooth GPS devices that have problems.
This is reason I decided to steer well clear of any Bluetooth GPS device. |
tom9851 Frequent Visitor
Joined: Feb 14, 2004 Posts: 283 Location: Warrington, Cheshire.
Posted: Thu May 20, 2004 7:10 am Post subject: |
cepheus1 - as technik righly says this is a bluetooth problem you refer to with the 2210.
There are two main issues currently being talked about on this forum. The bluetooth/2210 connection/drop-out problem and the TTN3 address look-up/map errors problem. If you have a wired 2210 you can safely install TTN3. I installed TTN3 straight from the CD only (didn't bother downloading the updated GPS driver from TT's site as didn't see the point as it was addressing a bluetooth issue) and experienced no problems whatsoever regarding GPS. I reverted back to TTN2 simply because I found the address look-up problem too much to bear!! You (as indeed others have) may take a different view on this, especially if you are using postcodes frequently with Neils's p/code application, in which case the diabolical problems encountered re address look-up aren't so critical as the p/code application works a treat with TTN3 as it does with TTN2. I, personally, am sticking with TTN2 until TomTom resolve this address problem, but judging from DavidW,s latest post on this issue I am not very confident of an early resolution! |
ttrevor Lifetime Member
Joined: Dec 04, 2003 Posts: 540 Location: Sleaford Lincolnshire UK
Posted: Thu May 20, 2004 7:44 am Post subject: |
No problems with my setup works a treat,i even get 4-6 sats on reception when my car is in the garage,i dont know if is the norm but thats how it is,i had a bluetooth system several months ago and had no joy with it at all,so reverted back to wired system
trevor _________________ Iphone x 64gb IOS 11.3.1 / IPhone 6 Plus 32gb IOS 12 beta /Volkswagen Scirocco R 280 bhp /Suzuki Vitara swb vvt+ /Suzuki Jimny special/running Apple Mac Mini / Apple air/ iPhone x /6 plus navigation / Apple car-play |
Posted: Thu May 20, 2004 8:50 am Post subject: |
Thanks guys!
Sounds like the only thing for it is to give it a whirl now for myself and see what I think about it then
Wish me luck!
I pretty much use Postcodes for all my addresses so here's hoping that I find it a little more useful.
Just out of interest can I do an install over the top of my current TTN2 or do I have to uninstall all the old "stuff" first?
Also, if I do not like TTN3 is it still possible to roll back to TTN2?
Thanks again 8) |
Posted: Thu May 20, 2004 11:11 am Post subject: |
Since you are using postcodes mostly then you will probably like TTN3 fine. Suck it and see! Just load TTN3 straight over TTN2 - just follow the loading instructions on the CD - dead easy! If you decide you want to revert back to TTN2 just delete all TTN3 from both your PDA and card and reinstall it - again no problems at all - I did it without any difficulty. Whether you can reinstall TTN2 over TTN3 I don't know - I wasn't sure so I just deleted everything - doesn't really take very long.
Good luck
Tom |
