Pocket GPS World :: View topic - changing the warning distance
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Destinator
dotdotdot
PostPosted: Fri Jun 13, 2008 9:28 pm    Post subject: changing the warning distance Reply with quote
hello all, I'm a newbie in using the Destinator, I've put in POIs, but it warns me way too early ahead of the POIs. How could I change the warning distance?
I'm using Destinator v.6
thanks all
alanf
PostPosted: Thu Jun 19, 2008 7:49 pm    Post subject: Reply with quote
If you have added locations, such as the speed cameras, they appear in Destinator as 'Favourites'. If you're on the map, tap 'menu' bottom right. From the locations menu, tap 'Favourites', at the bottom tap 'Alerts' and you can set 1st and 2nd alert distances in hundreds of yards/metres.
In Destinator 6 the one settings page covers all the favourite groups which are active (a tick beside them in the list). In v3 you could set separate distances for each of two groups so I had shorter distances set for redlights than for gatsos. Lost that in v6 which probably shows why Destinator has had a bumpy ride of late.
Acer n35, Destinator 3.0.75, Destinator 6
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Destinator All times are GMT + 1 Hour
23.061 (04 Jun 25)
