Pocket GPS World :: View topic - Getting a 920 of the windscreen mount
sven1
PostPosted: Tue Jun 17, 2008 10:53 am    Post subject: Getting a 920 of the windscreen mount Reply with quote
this seems quite hard. is there a trick to it or do I just slide it off using as much force as necessary! Not keen to break it!
Jon
PostPosted: Tue Jun 17, 2008 11:09 am    Post subject: Reply with quote
Should just slide off with little force required?
dhn
PostPosted: Tue Jun 17, 2008 11:50 am    Post subject: Reply with quote
The 920 mount is the same as a 720. I find holding the neck of the mount with one hand and with the thumb of the other hand on one side of the unit and the fingers on the other and then giving the unit a little rock side to side while applying upward pressure should do it.
sven1
PostPosted: Tue Jun 17, 2008 12:43 pm    Post subject: Reply with quote
cheers both. as long as thats the way it is and i'm not missing any magical release button!
Jon
PostPosted: Tue Jun 17, 2008 12:46 pm    Post subject: Reply with quote
You aren't pressing the release button Question
Good cos there isn't one Laughing
GPS_fan
PostPosted: Tue Jun 17, 2008 12:52 pm    Post subject: Reply with quote
Mine has one Wink
Thumb underneath pushing TT up and fingers pushing down against mount works for me Cool
Andy
PostPosted: Tue Jun 17, 2008 2:37 pm    Post subject: Reply with quote
It gets easier with time....
dhn
PostPosted: Tue Jun 17, 2008 3:04 pm    Post subject: Reply with quote
Uh, what does? Twisted Evil Twisted Evil
PostPosted: Tue Jun 17, 2008 4:02 pm    Post subject: Reply with quote
I was going to say "it rides up with wear"!
shadamehr
Banned
PostPosted: Tue Jun 17, 2008 11:00 pm    Post subject: Reply with quote
As has been said, it both gets easier, and softer to acheive (removing it from the mount, before the innuendos start again Laughing ) over time.
But, if it helps, let me share my method - and it's a one handed method at that.
What I do, is wrap my thumb under the BOTTOM on the device, and my four fingers over the top of the TomTom.
Then, I press with my middle two fingers, down onto the top of the neck of the mount further round, over the back of the device where i placed them. At the same time, I press UP with my thumb.
And I find that doing this, pushing the device up with the thumb, and in effect PULLING the device up by pushing down on the mount neck/up and away with the device, using my fingers over the top, makes it a doddle to get it off.
Practice this, and you'll get it - the key is the bit with the fingers though - getting them over the top, and using the middle two to press onto the mount neck, to use this to propel the device UPWARDS away from the mount.
Once you do, you can reverse the principle, and come to be adept at getting it ON with one hand too.
playswell
PostPosted: Sun Jun 22, 2008 12:13 pm    Post subject: two handed Reply with quote
I use the two handed method myself............ easier and a quicker release
Calomax
PostPosted: Sun Jun 22, 2008 4:44 pm    Post subject: Reply with quote
My 720 just slides on & off with one hand. No need to hold the mount at all. The only thing that's a little awkward is lining it up in the first place.
TT Go Essential
22.062 (12 Jun 24)
