raboyme Regular Visitor
Posted: Wed May 19, 2004 7:24 am Post subject: Tom Tom wired GPS cable lenght? |
Hello!
Is it ok to use a 3 meters or a 6 meters cable between TomTom wired silver and the PocketPC, or does it make some negative effects with the signal etc.?
I ask this, because I need to put the GPS receiver to the rear window of my car, and I'll get a factory made cable with the lenght of 3 or 6 meters.
Roy |
ttrevor Lifetime Member
Joined: Dec 04, 2003 Posts: 540 Location: Sleaford Lincolnshire UK
Posted: Wed May 19, 2004 7:50 am Post subject: |
Roy ,no problem i have mine on the rear pacel shelf and the only extension lead i could get at the time was 5 mtrs long i just coiled up the excess and hid it under the rear seat
cheers trevor _________________ Iphone x 64gb IOS 11.3.1 / IPhone 6 Plus 32gb IOS 12 beta /Volkswagen Scirocco R 280 bhp /Suzuki Vitara swb vvt+ /Suzuki Jimny special/running Apple Mac Mini / Apple air/ iPhone x /6 plus navigation / Apple car-play |
Posted: Wed May 19, 2004 7:57 am Post subject: |
Ok, thanks!
I'll work it out with the longer cable then.
Roy |
DavidW Pocket GPS Moderator
Posted: Wed May 19, 2004 12:30 pm Post subject: |
There'll be no effects on reception if you use an extension cable - the GPS radio signals are decoded in the little silver GPS device. I wouldn't think adding a few extra metres of cable will disrupt the serial port connection (especially as it's usually at a very pedestrian 4800bps) or cause excessive voltage drop on the power wires.
Do, however, check that the extension cable you use is wired straight through. At least one person accidentally fitted a crossover one, destroying his GPS in the process.
David |
