Pocket GPS World :: View topic - Data-logger
Data-logger
jlw
PostPosted: Sat May 15, 2004 6:34 pm    Post subject: Data-logger Reply with quote
What is a Data-logger good for?
PostPosted: Sat May 15, 2004 8:49 pm    Post subject: Reply with quote
It's good for logging a track of where you have been like a breadcrumb trail and for you to either play it back later, or to plot it on a map to show where you have been.
True dataloggers do not need connection to any software to record their position, but may need an add-on antenna if one isn't included in the solution.
Scouser
PostPosted: Sun May 16, 2004 5:23 pm    Post subject: Reply with quote
Can you get a Data Logger package for the Meridion setup??[/b]
I didn't do it, it was like that when I got here HONEST
Scouser
PostPosted: Mon May 17, 2004 11:47 am    Post subject: Reply with quote
Edit: What an Eejit I am, I meant to ask Can you get a Data Logger package for the Medion Navigator setup??
PostPosted: Tue May 18, 2004 10:35 pm    Post subject: Reply with quote
Yes in theory. From what I recall the Medion isn't BT enabled though so it rules out the RBT3000. You can get a box that uses a 9v PP3 battery and has a serial port, if you can get a cable rigged from that to a PDA connector then there's no reason why you can't use it to connect to a PDA.
However, if you don't need to use it to playback on the PPC, then all you need to do is download log files to a PC and playback say in InfoMap Navigator or something similar.
