tazg101 Occasional Visitor
Posted: Sun Jun 08, 2008 7:12 pm Post subject: update problems |
My memory card recently crashed so I had to restore my backup from my PC onto my new card. Tomtom one V1.
I have done the necassary reinstall procudures but for some reason everything works fine (when you can operate TOMTOM via computer) under HOME 2.5 (I can view my maps etc fine) but when I switch the tomtom on standalone it says no map found and it won;t let me proceed:(
does anyone know what I done wrong? the map I have purchased is legit from the tomtom website about 1 month ago. |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10644 Location: Suffolk, UK
Posted: Sun Jun 08, 2008 9:04 pm Post subject: |
Have you tried a pin-in-the-hole Reset?
Was it a HOME Backup, or done using Explorer? _________________ Richard
TT Via 135 App 12.075: Europe Map v1150 |
Posted: Sun Jun 08, 2008 9:11 pm Post subject: |
hi, I have tried the pin reset and still not working.
to reload my memory card I did the following as I tried restore but was coming up with problem mentioned.
Used older version of HOME to reinstall application (which was saved on computer) then used HOME 2.3 to update this and reinstalled map which was copied on my computer.
the app version installed is 7.163
and my map is UK and IRELAND 715.1689. |
Posted: Sun Jun 08, 2008 9:32 pm Post subject: |
tazg101 wrote: | map which was copied on my computer. | With HOME or Explorer? _________________ Richard
Posted: Sun Jun 08, 2008 10:06 pm Post subject: |
I installed the MAP with HOME. |
Posted: Mon Jun 09, 2008 6:24 am Post subject: |
I can't understand how it works with Operate my Device and not under it's own control.
I take it that you get the No Maps Found when you go to Switch Maps. _________________ Richard
Posted: Mon Jun 09, 2008 8:29 am Post subject: |
I can't even get up to that screen.
I swtch the device on then it pops up 'no maps found'. if i click the screen I can't access the menu's or anything. |
Posted: Mon Jun 09, 2008 10:27 am Post subject: |
In HOME did you use Backup and Restore or Add Map, etc | Items on my Computer to put the Map back on?
I'm running out of ideas.
It might need a call to TT Customer Services. _________________ Richard
Posted: Mon Jun 09, 2008 10:53 am Post subject: |
I used the Add Map, etc | Items on my Computer function
as if i did the Restore backup I had a similar problem. I did the back up from the same device as I only have one tomtom |
alanji Lifetime Member
Posted: Mon Jun 09, 2008 3:05 pm Post subject: |
I had a similar problem (screen freezing on start up) after downloading the latest upgrade. Helpline instructions were to delete all "loose" files on sd card (NOT folders), reset, reconnect to computer and download update.
It did work for me but is still freezing if I download the latest upgrade. |
Andy_P Pocket GPS Moderator
Posted: Mon Jun 09, 2008 8:36 pm Post subject: |
Yet more evidence to show that you need to do FULL backups with Windows Explorer NOT "Home".
Home has a long reputation for screwing up its backups, and apparently the latest versions of Home don't even let you keep more than one, which is plain crazy!
Instructions to make proper backups are in the FAQs in this forum. |
Posted: Tue Jun 10, 2008 6:22 pm Post subject: |
Andy_P wrote: | Yet more evidence to show that you need to do FULL backups with Windows Explorer NOT "Home".
thanks for that very helpful  |
Crocodile Regular Visitor
Posted: Tue Jun 17, 2008 9:58 am Post subject: |
alanji wrote: | I had a similar problem (screen freezing on start up) after downloading the latest upgrade. Helpline instructions were to delete all "loose" files on sd card (NOT folders), reset, reconnect to computer and download update.
It did work for me but is still freezing if I download the latest upgrade. | Can you define what you mean by "loose" files? |
Posted: Tue Jun 17, 2008 9:59 am Post subject: |
Crocodile wrote: | Can you define what you mean by "loose" files? | Files in the Root of the Device , that are not in any Folder. _________________ Richard
