Pocket GPS World :: View topic - 250W USB Problem
250W USB Problem
spib
PostPosted: Sun Jun 08, 2008 9:59 pm    Post subject: 250W USB Problem Reply with quote
I can't seem to get my 250W to go into Mass Storage Mode no matter what I do. I've got a mini-usb cable which I know works because I use it with my camera. I turn off the 250W, insert the usb cable and the 250W then boots up. However, it's just in normal mode, there is no icons on the screen at all and on all 4 pcs I've tried there is no USB device showing, no 'searching for drivers' or anything.
Have I got a duff unit?
James
PhilHornby
PostPosted: Sun Jun 08, 2008 10:35 pm    Post subject: Re: 250W USB Problem Reply with quote
spib wrote:
I turn off the 250W, insert the usb cable and the 250W then boots up. However, it's just in normal mode...no 'searching for drivers' or anything.
There's a faint possibility, that your 'camera' USB cable contains the same resistor, that Garmin use to signal that it is a charger that's attached. Trying another cable would eliminate that.
My original StreetPilot C510 was replaced by Garmin, because it stopped being recognised by the PC, so a similar fault on your Nüvi is a possibility.
22.064 (26 Jun 24)
