Pocket GPS World :: View topic - TOMTOM 930 PROBLEM URGENT MATTER OF LIFE :(!
Goto page Previous  1, 2, 3
richieseel
PostPosted: Tue Jun 03, 2008 10:26 pm    Post subject: Reply with quote
yep, unpack and drop zip folder into tomtom root.
Didn't even have to reset it just turn it on and off
PostPosted: Wed Jun 04, 2008 2:42 am    Post subject: Reply with quote
That seems to be a GOOD new link Thumbs Up
Still the same versions, v701 UK and v710 NL, but none of the daft needing to be logged into your TomTom account to (maybe) get it any more. AND it has got the "version" files included, so we know where we stand!
Smeg77
PostPosted: Sun Jun 08, 2008 1:47 am    Post subject: Reply with quote
It does seem that TomTom have neglected this in their 930T. There is a Postcode file inside each of the map folders, so I'm guessing that is where some of the partial searching is coming from. Also I keep seeing people say don't use a space when typing postcodes, where is the space as I don't seem to be able to find one on mine, and even street names are written all as one word.
As far as I can tell on the TomTom site this should work 'straight out of the box' and should work for all countries
http://tomtom-uk.custhelp.com/cgi-bin/tomtom_uk.cfg/php/enduser/popup_adp.php?p_faqid=9699&p_created=1211183919
Not knowing any non-uk postcodes I can't test it. Ok this is quite amusing, just looked up the postcode for the Louvre and it's not in the TT930T, there does seem to be quite a few French codes in there but not that one, and the best bit, using the example given in the TT helpsite (link above) it doesn't even have the Netherlands postcode used in the example.
Glad I found this fourm, as I've raised a support ticket with TT but they're only open Mon-Fri so it won't be picked up till then.
JockTamsonsBairn
PostPosted: Sun Jun 08, 2008 11:07 am    Post subject: Reply with quote
From memory, only the Netherlands use postcodes in the same way as we do in the UK. (I know that french addresses contain 5(?) digit codes, but I don't think that they relate to the geographical location in the same way as a UK postcode. An expert will be along shortly to explain it to us, or possibly a search would reveal the details.) TT only support postcode searches for UK & Netherlands (in v6 at least).
Jock
PostPosted: Sun Jun 08, 2008 11:17 am    Post subject: Reply with quote
You are correct that only UK and Netherlands use the true postcode system, in order to enter/ use a postcode for the UK you need to be in the UK, the same applys to Netherlands - you need to be in country for it to work. - Mike
PostPosted: Sun Jun 08, 2008 2:13 pm    Post subject: Reply with quote
IIRC and you are in a country other than the UK or the Netherlands, choosing the Postcode Menu will give the chance to choose which Country you want to use.
TT Via 135 App 12.075: Europe Map v1135
PostPosted: Sun Jun 08, 2008 3:40 pm    Post subject: Reply with quote
On every Go I've ever had, the postcode entry page has a normal QWERTY keyboard, complete with spacebar.
On current software you can hit the spacebar if you want, but it is ignored and makes no difference to what gets entered.
...and even street names are written all as one word.
Eh? I've never seen that! Can you say exactly what screen/s it happens on?
Smeg77
PostPosted: Mon Jun 09, 2008 5:56 pm    Post subject: Reply with quote
I've just found the space key. I've always used the Postcode search and it has been removed from that screen.
I have received a reply from TomTom today, and they have said if you tell them what map version you are using they will send the postcode file for it.
petertherascal
PostPosted: Sun Aug 02, 2009 9:53 am    Post subject: Reply with quote
Copoboxx wrote:
Nevermind.. It was the mem card..
Let's focus on the zip folder.. How do i replace it?
EDIT: putting zip folder now..
Well I've gotta say THANKS SO MUCH xD :D Wow! Works great now :P
The only problem is this is only GB And Nederland i think? What about the other countries? Because this summer i'll be going to Turkey via Car from London and maybe i'll require Postcode?
I have a new 930T with the same lack of full postcodes [surly this is a MASSIVE bug in such a device?]. I have No memory Card. No Zip folder. PLEASE could someone clairify how I can fix it
Steveee
PostPosted: Sun Aug 02, 2009 10:24 am    Post subject: Reply with quote
Zip file at:
http://tomtom.com/updates/zipcodes/map7/wezipcodes715.zip
As richieseel said, just unpack and drop in root.
Steveee
Where am I?
GO 920 (retired)
Garmin Oregon 550T
Garmin Drivesmart
molerat
PostPosted: Sun Aug 02, 2009 1:10 pm    Post subject: Reply with quote
Download the newer v801 from here http://www.oldboy.me.uk/TomTomUpdates/zip.zip
PostPosted: Wed Aug 05, 2009 9:27 pm    Post subject: Reply with quote
Steveee wrote:
Zip file at:
That's an older version....
Use Oldboy's link.
Page 3 of 3
22.094 (25 Sep 24)
