fender1 Occasional Visitor
Posted: Mon Jun 02, 2008 9:41 pm Post subject: Camera icons on a nuvi 310 |
I've just joined and admit I'm a novice!
I have successfully loaded the latest database with Garmin POILoader to my nuvi however when I look at the map onscreen, all cameras are shown as a grey dot, not the bmp camera icons that I also downloaded too. The POI alerts are on and warn me of an upcoming camera so is there something else I have missed?
Fender1 |
Posted: Mon Jun 02, 2008 11:28 pm Post subject: |
OK. Which database did you install - Single File, Consolidated or Speed Zoned?
Did you change anything at all?
Quote: | not the bmp camera icons that I also downloaded too |
Did you download seperate BMPs for the database? If so, which one? What pixel size?
Also can you try using the BMPs that came in the download and re-send them to the Garmin. |
Posted: Tue Jun 03, 2008 9:12 pm Post subject: |
Hi, thanks for the swift response. Here is some more info...
I have downloaded the speed zoned individual camera file latest version ended cams-vXXX. I then extracted the csv's and bmp's to a POI folder on the PC, combined with the other POI's from the site (restaurants etc). I then used POIloader which successfully put approx 150k files to the nuvi without changing any files.
I only used the original bmp's from the zoned download 22x22 pixels. The nuvi is bang up to date with software from Garmin on version 4.2 and I have used two different releases from the last couple of weeks with exactly the same results.
Hope that helps!
filename edited by MaFt |
Posted: Tue Jun 03, 2008 11:10 pm Post subject: |
I notice you have added "150k files ". Can you confirm all the other POIs show up OK? What if you load the Speed Camera Database on it's own? |
Posted: Wed Jun 04, 2008 10:30 pm Post subject: |
Now we're getting somewhere!
The other POI's do appear under the CustomPOI's folder with the cameras when all files are loaded. However when I load the cameras only, the icons now appear on the map.
So is there a memory limit on number of files or file size on the nuvi that is causing this issue, so maybe should I add all POI's to an SD card maybe?
Thanks |
Posted: Thu Jun 05, 2008 9:11 am Post subject: |
IIRC there was a limit with the 310 units which was fixed by one of the latest firmwares. However it looks like there might still be a limit but the unit just doesn't lock up any more... |
Posted: Thu Jun 05, 2008 10:08 am Post subject: |
The limit was 257 custom POI categories and it didn't matter where the POI files were stored, this used to lock up the devices - Mike |
Posted: Thu Jun 05, 2008 10:23 am Post subject: |
That's it - was looking in the wrong place. Just remembered it's on the POI download page.
Quote: | Special Note to nuvi users: DO NOT TRY TO INSTALL MORE THAN 257 POI CATEGORIES AS THIS WILL CAUSE YOUR UNIT TO FAIL TO BOOT! It is advisable to install the POIs onto a separate SD Card so if you do have problems then you can remove the poi.gpi file from the memory card from a separate card reader.
LATEST:
This issue has been resolved with version 3.90 of the firmware for nuvi 310 and 360.
This issue has been resolved with version 4.60 of the firmware for nuvi 300 and 350.
This issue has been resolved with version 4.10 of the firmware for nuvi 660. |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15154 Location: Bradford, West Yorkshire
Posted: Thu Jun 05, 2008 10:43 am Post subject: |
when they 'almost' admitted their error they claimed it was down to the number of bitmap files as opposed to csv files - you could always try removing some bitmaps from other poi sets and see if that affects the speed camera ones?
MaFt |
