Calvyn_Harkness Occasional Visitor
Posted: Thu May 29, 2008 1:47 pm Post subject: Hello, sorry if this is the wrong area, need help. |
OK, so i have just recieved a second hand HP Ipaq ( I cant remember the model number it is very complicated, its the one with nevo home control (great fun) ).
I also have a Fortuna BT Bluetooth GPS clip-on dongle thing.
Now on my Ipag i have been trying to get winfast navigator to connect to it, with little success.
There are many different settings, i have managed to work out that the bluetooth out port is COM 6.
But i am having some right trouble, there is a switch on the side of the dongle labeled "ST" and "XT".
My brother left no instructions and i am thoroughly bamboozled.
Any help? |
![](modules/Forums/images/avatars/32928398450ec149ec6abd.gif)
Joined: 30/12/2002 17:36:20 Posts: 4914 Location: Oxfordshire, England, UK
Posted: Thu May 29, 2008 3:46 pm Post subject: |
Hi Calvyn_Harkness,
to the forum!
Are you using a CF or SD card?
Some iPAQs didn't like to use Bluetooth GPS units when you used an SD card. this is easily overcome by using a CF card.
Secondly, try switching the infra red function off as that sometimes caused an issue.
Garmin Camper 770 LMT-D |
Posted: Thu May 29, 2008 5:02 pm Post subject: |
Thankyou.
I have no card in the reader on top.
And i will just try swithcing off the beam'er.
Nope, doesnt work, it says that it cant find the serial ports on the dongle.
port 8 is in the in port 6 is the out for my Ipaq |
philpugh Lifetime Member
![](modules/Forums/images/avatars/gallery/bass_fret.jpg)
Joined: Dec 28, 2005 Posts: 2003 Location: Antrobus, Cheshire
Posted: Fri May 30, 2008 10:31 pm Post subject: |
What version of Windows is it running?
You may be better to delete the original pairing of the PDA to the BT GPS and start from scratch. But make sure you know what hte pairing code is before you do this. It's usually 0000 but some manufacturers make it different.
If your system is running some sort of GPS port sharing sharing software, disable this. WM5 introduced this feature and it can cause problems with some applications. Seems to work better with WM6.
On my DELL Axim WM5 (and WM6) give me ports 6 and 7 for my BT GPS(es). _________________ Phil |
![](modules/Forums/images/avatars/gallery/Sphere_animated_small_neg2.gif)
Posted: Fri May 30, 2008 11:02 pm Post subject: Re: Hello, sorry if this is the wrong area, need help. |
Calvyn_Harkness wrote: | But i am having some right trouble, there is a switch on the side of the dongle labeled "ST" and "XT". |
Does THIS assist, it certainly explains the two switch positions ST and XT which might help and the confusion the switch can lead to - Mike |
Posted: Sat May 31, 2008 12:23 am Post subject: |
Ok.
Thanks.
Now i can get a connection on Sirf baud 57600.
BUT!
On standard mode it says it cannot find a port on the device and X does not work.
I will continue fiddaling.
Thankyou for the help! |
