Pocket GPS World :: View topic - talking speed alerts
tt4uk
PostPosted: Tue May 27, 2008 7:34 pm    Post subject: talking speed alerts Reply with quote
where can i find the sound files ie 30mph alert etc instead of the bong
to install on my 760T
PaulB2005
PostPosted: Tue May 27, 2008 7:51 pm    Post subject: Reply with quote
They are here but you'll need to convert them to mp3 with a program like Audacity.
tt4uk
PostPosted: Tue May 27, 2008 8:01 pm    Post subject: Reply with quote
thanks..where do i get that program??
PostPosted: Tue May 27, 2008 8:30 pm    Post subject: Reply with quote
http://sourceforge.net/projects/audacity/
Alfaholic
PostPosted: Thu May 29, 2008 10:47 am    Post subject: Reply with quote
If I convert these files to mp3 can I then use them on my Nuvi 250W?
PaulB2005
PostPosted: Thu May 29, 2008 12:34 pm    Post subject: Reply with quote
It appears only the models with mp3 players support mp3 alerts. As the 250W doesn't have an mp3 player i'd say no. However if you get an older copy of POILoader such as the 2401 Beta version here you can use WAV files in the same way.
However, this is a Beta (test) release of POILoader and is not supported by Garmin. The wav function was also dropped for some reason from future releases. Use at your own risk.
PhilHornby
PostPosted: Thu May 29, 2008 1:34 pm    Post subject: Reply with quote
Just as quietly as they dropped it, they re-introduced it! - it's back in POILoader V2.5.2
See also: Arrow http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=65827
I asked Garmin if they could confirm all the recent, undocumented changes to POILoader. UK support said they would pass my request onto the developers. Still no response after a month Sad
PaulB2005
PostPosted: Thu May 29, 2008 4:22 pm    Post subject: Reply with quote
...and i read that thread the other day and promptly forgot it..... Embarassed
tt4uk
PostPosted: Sat May 31, 2008 9:57 am    Post subject: Reply with quote
done that...converted to mp3...downloaded to the same directory as speed warnings...it still "Bongs" and the mp3 does not play Confused
tomthompson
PostPosted: Sun Jun 01, 2008 4:27 pm    Post subject: Reply with quote
Because I have a garmin streetpilot 2720 I have been using the beta POIloader and .wav files . Reading this thread I thought whoopee I can go to latest poiloader and still have talking warnings so being foolhardy I downloaded it .
Then downloaded the speed camera database down again and went for a drive past my local gatso.
It may work for some but it screwed my 2720 up royally . I dont seem able to drive on roads now but in the space between roads . And there are no POIs showing on the screen at all so no sound either .
Back to betaPOILoader for me . Rolling Eyes
Asus Zenfone 2 twin sim, Garmin Zumo 550, 660 and pocketgps speed camera database
I keep on learning but they invent new things faster ,How do I keep up ?
tomthompson
PostPosted: Sun Jun 01, 2008 4:47 pm    Post subject: Reply with quote
I had a ponder on this and decided to try again ,but first I will remove all pois via poiloader .
I do remember that when I started using the Beta version that I had to delete all because they must be a different format and they were clashing with each other.
Having done this I can now see the pois on the map so its out again to drive past my local gatso to see if cynthia tells me all about it. Idea
tomthompson
PostPosted: Sun Jun 01, 2008 5:37 pm    Post subject: Reply with quote
Thats it . It works
So for all those that dont have mp3 on their garmin satnavs .
Use .wav sound files , name them the same as the data files and .bmp files.
Download sox.exe to garmin directory
Then you can use the latest POILoader
If it works on my 2720 it should work on most other units that support sounds
Oh and by the way I use ash's camera manager software (donated) cos it also supports putting voices to each camera type .
Superb , no more mucking about with beta progs
Thanks all for this thread.
Bought me right up to date
Very Happy
PaulB2005
PostPosted: Mon Jun 02, 2008 9:03 am    Post subject: Reply with quote
Done what, exactly?
You have to put the mp3 into the same directory as your Speed Camera Database and then upload the lot using POILoader. You also have to make sure the mp3 has the same name as the file you want to alert for.
i.e. if you have the following files
pocketgps_uk_gatso.csv
then you need to name the mp3 you wish to use as
pocketgps_uk_gatso.mp3
same again for
pocketgps_uk_mobile.csv
make
pocketgps_uk_mobile.mp3
etc
Then upload all these using POILoader.
GPSinC3
PostPosted: Fri Jun 06, 2008 5:29 pm    Post subject: Reply with quote
Did the conversions for Garmin NUVI 760, renamed and they worked fine. Thedn downloaded Ash Camera manager, redid mp3 files to match the files that POI loader was sending but back to beep, not over worried but interested in why, is it to do with different file formats that camera manager creates noit csv s ?
22.071 (03 Jul 24)
