Pocket GPS World :: View topic - Best for Multi Route?
designer7
PostPosted: Sun May 25, 2008 12:28 pm    Post subject: Best for Multi Route? Reply with quote
Hi.
Having to replace my Navman 530 due to the fact that Navman no longer offers updates only support for the 530.
I use it every day for work with the multi trip option which will let me add 14 stops in one trip and will calculate the total trip time , eta ,mileage etc and shows turn for turn for the whole trip showing distance to each stop in turn in the route information section
I've tried the s90i but this will only give the same information for each individual stop not the whole trip, although there is a basic summary in the route mode.
Basically....I need the best multri trip function across any of the brands, any suggestions of ones i could take a look at?
alix776
PostPosted: Sun May 25, 2008 7:43 pm    Post subject: Reply with quote
if you can still get one have a look at mio as they ran igo2006 or a version of it this would allow 100 way points
or look at a pda with either igo copilot7 or directions navigator
device Lumia 950 xl
gatorguy6996
PostPosted: Sun May 25, 2008 8:41 pm    Post subject: Reply with quote
The Garmin nuvi 7x0's will not only allow you to enter multiple stops, but you can enter in any order you want, then let the nuvi automatically optimize the route for the fastest travel to hit each of the stops. Much easier to do on the 700's than nearly any of the others. No guessing as to which stop should be next. Allows 50 stops per route and up to 10 saved routes (there is a workaround for that as well if you need more than 10)
Garmin 1695 / 255 / 760 w/MSN - Droid w/Google nav + Navigon - Navigon 8100T - Dakota10 - GPSMap76C - GeoMate Jr.
Border_Collie
PostPosted: Sun May 25, 2008 11:43 pm    Post subject: Reply with quote
Route optimisation, time/distance to next stop/via/waypoint, time/distance to final destination (usually back where you started). Add a POI Group of customers. Lorry mode if needed All this can be had on iGO 2006 and if you go for iGO 2006 PLUS you get Post Code Search.
The advantage with iGO is it's locked to the SD Card, so buying one second hand will create no problems with Activation.
If you happen to be near the Medway Towns I could show you what it can do. CoPilot
22.063 (19 Jun 24)
