Pocket GPS World :: View topic - help
help
garyowens
PostPosted: Thu May 22, 2008 7:27 pm    Post subject: help Reply with quote
downloaded the correct voice files for my pda running tomtom 6, but vant get the voices to work, anyone any help???
thanks Gary
PostPosted: Thu May 22, 2008 7:31 pm    Post subject: Reply with quote
Gary, which voice files are you trying to use the camera waring ogg files or something else? - Also can you let us know the PDA type that you are using? this information will lead to a more accurate answer to the problem - Mike
garyowens
PostPosted: Thu May 22, 2008 7:34 pm    Post subject: re Reply with quote
hp ipaq hx2190
garyowens
PostPosted: Thu May 22, 2008 7:35 pm    Post subject: sorry Reply with quote
sorry yes the ogg files
PostPosted: Thu May 22, 2008 8:03 pm    Post subject: Reply with quote
As long as you have the correct ogg sound pack that matches the Speed Camera database type you have installed AND put the ogg files into the map folder along with the POI files this will work.
You do need to re-set each Speed Camera POI warning though by going to Change Preferences/ Manage POI/ Warn when Near POI and go through the motions of reselecting the distance applicable etc.
When you have done the above for each camera type installed try the folloing to make sure it is working:
Go to AtoB Planning or Advanced Planning (I have forgotten the exact name in the PDA version).
Set a departure point of FY43NN house number 95
Set a destination point of PR41AX House number 33 (or near that number)
now use Route Demo set to a replay speed of 100% to replay the above route on the device, you should get the following warnings within about 5 to 10 minutes of watching the unit:
Gatso 30
Mobile 30
Mobile 40
Gatso 50
Mobile 50
Mobile 30
Hope that helps - Mike
garyowens
PostPosted: Thu May 22, 2008 8:48 pm    Post subject: re Reply with quote
thanks got some success with some cams, not all
PostPosted: Thu May 22, 2008 8:53 pm    Post subject: Reply with quote
What is the problem, do the other cameras not appear in your list of POI when trying to configure the warnings? - If so check how many files ending with the ov2 file extesion are in your map folder, TTN6 has a limit of 100 custom OI categories (POI's).
If its not the above which cameras works and which ones don't? - Mike
garyowens
PostPosted: Thu May 22, 2008 10:08 pm    Post subject: sorted Reply with quote
thanks for you help[, got them sorted all sorted now, my mistake, missed a load of cams not enabled,,,,,,,,silly me doh!!!
