R1chard Regular Visitor
Posted: Fri May 14, 2004 11:26 pm Post subject: Switching Voice Files |
What I'd like to be able to do is to switch between different voicefiles (i.e. English and French) without having to install files via ActiveSynch or a card reader. In other words I want to be able to do this without involving my PC.
I could store the alternative voice files on my Ipaq2210 or on a CF card so a nice little app would be fantastic if it could automate the switching of the files. But I guess that's asking too much so is there a relatively pain-free way make this happen manually?
Cheers.
Richard |
lbendlin Pocket GPS Staff
Posted: Fri May 14, 2004 11:34 pm Post subject: |
How many more people will be interested in that? Writing the app is relatively easy, but is it worth the effort?
Manually you can do that in the registry.
HKCU\Software\TomTom\TomTom Navigator\Voice\LastInstalled _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Sat May 15, 2004 7:39 pm Post subject: |
lbendlin wrote: | How many more people will be interested in that? Writing the app is relatively easy, but is it worth the effort?
HKCU\Software\TomTom\TomTom Navigator\Voice\LastInstalled | I don't know how many people would be interested but it doesn't feel to me like an outrageous request. I have a mobile phone which allows me to switch between 4 or 5 languages very easily without going through a lengthy download procedure so it doesn't seem unreasonable that a piece of software that retails internationally might have a similar facility.
I don't really understand the registry changes I would need to make using your suggestion. Can you be a bit more specific as it looks like it might be the answer for me.
Cheers.
Richard |
DavidW Pocket GPS Moderator
Posted: Sat May 15, 2004 8:32 pm Post subject: |
One big difference between your phone and a Navigator voice is that the voice files are relatively large - about 3.5MBytes.
If you want a totally Pocket PC way of installing different voice files, you could copy the CAB files relating to the voices you want to your storage card, and make them read only. You then use Remove Programs to remove your existing voice (Start Menu, Settings, System tab, Remove Programs) then tap on the CAB of the voice you want to install in a file manager. If the CAB file wasn't marked as read only, it will be deleted once it's installed.
David |
Posted: Sun May 16, 2004 3:42 pm Post subject: |
Thanks David - sounds like I'm getting closer to a solution.
So what I think you're saying is that I could store both versions of the CAB files as "read only" on my CF card, then when I want to switch from one language to another I would remove the currently installed files using "remove programs" then tap in the CAB file of the target language files which would install the new files.
A bit clunky but nevertheless it sounds like a viable option - it's not as if I want to be switching laguages every other day but I can envisage times I would want to do it when I don't have a PC available - like when I'm abroad (or when I'm just bored!).
Cheers for the help.
Richard |
Posted: Sun May 16, 2004 4:04 pm Post subject: |
No need to delete the currently installed sound files. simply install the other one and accept the " reinstall" _________________ Lutz
Posted: Sun May 16, 2004 6:17 pm Post subject: |
Very true - though TomTom have sometimes used different 'application names' in voice CABs in the past - which can leave redundant entries in the Remove Programs list if you don't uninstall.
David |
Posted: Sat May 29, 2004 8:41 am Post subject: |
I've now achieved a solution which enables me to quickly switch between languages. This could also be useful if you like to switch between male and female voices in the same language.
Although this is not quite how I did it, I think this is the best non-technical procedure:
1) Copy the existing installed folder and contents "program files/navigator" to another location (say your CF Card).
2) Rename the folder to something like "navigator_english".
3) Move it back to the program files folder.
4) Install your second language/voice files from the installation disk in the normal way so that when you fire up the application it will be using the second language.
To switch between languages/voices use the explorer application to:
1) Locate the program files folder
2) Rename "navigator" to something like "navigator_french"
3) Rename "navigator_english" to "navigator"
4) Fire up TTN.
What this does is to have two versions of TTN installed - one in each language. So to switch between them you simply need to ensure that the folder contaning the language/voice you want to use is named "navigator" and the one you're not using is named something else.
I'm not quite sure yet what impact this has on the TTN configuration settings e.g. if you change a setting whilst running the English version would you need to change the sae setting when you run the French version?
The reason for using the installation disk instead of extracting the CAB files is that the extracted CAB files then have to be renamed per the ini file which comes with the CAB folder. As there's 59 voice files this can take a long time to do manually and is open to error although you can, if you're carfeful, use a bulk file renaming program to do the job for you.
Richard |
Genie Occasional Visitor
Posted: Sat May 29, 2004 9:03 am Post subject: |
Excellent. I just found your post and wanted to do extactly the same.
I'm off to germany today, so Ive' done like you say and set the voice files up to german and can switch betweeen english and german.
Cool. _________________ Ipaq 4150, Polstar PBT-111, TomTom3, Kingston 256mb SD, Arkon Powered Amplified PDA Mount |
MrT Frequent Visitor
Posted: Sat May 29, 2004 9:42 am Post subject: |
Am I missing the point here, but why when in a different country do you want to listen to directional commands in another language? |
Parky Regular Visitor
Joined: 25/05/2003 09:12:02 Posts: 247 Location: Bradford UK
Posted: Sat May 29, 2004 2:35 pm Post subject: |
I was just thinking the exact same thing, why !!! |
Posted: Sun May 30, 2004 10:06 pm Post subject: |
I can't speak for Genie but as I speak both English and French it feels more natural to listen to the commands in French when I'm in a French speaking country (as I am right now).
Richard |
Posted: Sun May 30, 2004 10:38 pm Post subject: |
I guess it did sound a bit wierd.
I´m here in Germany at the moment and living for a couple of weeks with relatives.
They are fluent german speakers, so I stick it in his car for his benefit as we are planning on a long family trip (Switzerland)
When I need to hire a car, i´ll just switch it back to English.
As you can guess I can´t keep away from Pocket GPS World even when on holiday! :D _________________ Ipaq 4150, Polstar PBT-111, TomTom3, Kingston 256mb SD, Arkon Powered Amplified PDA Mount |
joejoe123 Occasional Visitor
Joined: Mar 06, 2004 Posts: 39 Location: Vienna , Austria
Posted: Mon May 31, 2004 9:43 pm Post subject: |
I have seen this "Voice switcher" in another post in this forum , maybe you try it . i am happy with Jane all the time :D
http://members.chello.nl/~ravelin/ |
