jlw Frequent Visitor
Joined: May 10, 2004 Posts: 402 Location: South Sweden
Posted: Sat May 15, 2004 6:34 pm Post subject: Data-logger |
What is a Data-logger good for? |
Dave Frequent Visitor
Posted: Sat May 15, 2004 8:49 pm Post subject: |
It's good for logging a track of where you have been like a breadcrumb trail and for you to either play it back later, or to plot it on a map to show where you have been.
True dataloggers do not need connection to any software to record their position, but may need an add-on antenna if one isn't included in the solution. |
Scouser Occasional Visitor
Posted: Sun May 16, 2004 5:23 pm Post subject: |
Can you get a Data Logger package for the Meridion setup??[/b] _________________ I didn't do it, it was like that when I got here HONEST |
Posted: Mon May 17, 2004 11:47 am Post subject: |
Scouser wrote: | Can you get a Data Logger package for the Meridion setup?? |
Edit: What an Eejit I am, I meant to ask Can you get a Data Logger package for the Medion Navigator setup?? _________________ I didn't do it, it was like that when I got here HONEST |
Posted: Tue May 18, 2004 10:35 pm Post subject: |
Yes in theory. From what I recall the Medion isn't BT enabled though so it rules out the RBT3000. You can get a box that uses a 9v PP3 battery and has a serial port, if you can get a cable rigged from that to a PDA connector then there's no reason why you can't use it to connect to a PDA.
However, if you don't need to use it to playback on the PPC, then all you need to do is download log files to a PC and playback say in InfoMap Navigator or something similar. |
