Pocket GPS World :: View topic - TOM ONE V3 Home charging & charge time
D4VE
PostPosted: Mon May 19, 2008 12:27 pm    Post subject: Reply with quote
Yes you can charge the unit from a compter using the usb cable supplied.
I have my unit connected to the car charger whenever I am in the vehicle, so it rarely goes flat, but every now and then I do let it run down and give it a full recharge. A legacy I have continued with all rechargeable batteries even though its not needed with NiMH batteries.
iPhone4 IOS 4.3.3
TomTom Western Europe v865.3252
App 8.300 V1.6 (670441)
TomTom iPhone Car Kit
PC Operating System: Windows 7
Oldboy
PostPosted: Mon May 19, 2008 12:56 pm    Post subject: Re: TOM ONE V3 Home charging & charge time Reply with quote
onesexylady wrote:
What I wanted to know is can she charge it through the computer with the usb cable that came in the box with it? If not what is the best thing to get for charging indoors?
Yes, you can charge it via the USB lead, but bear in mind that it is only a low charge rate.
You can get Mains Chargers, but they must have a minimum of 2A capacity.
onesexylady wrote:
Does it keep charging itself up while its in the car and do you think its really necessary to get another home charger?
If it is in use everyday in the car, there would be little need for a home charger.
The car adapter should be able to charge a flat battery in about 2 hours. And that's with the Device working. Smile
Oldboy
PostPosted: Mon May 19, 2008 1:00 pm    Post subject: Reply with quote
D4VE wrote:
... but every now and then I do let it run down and give it a full recharge. A legacy I have continued with all rechargeable batteries even though its not needed with NiMH batteries.
TomTom Devices use either a Lithium-ion or Lithium-polymer Battery.
This is extracted from http://www.batteryuniversity.com/parttwo-34.htm
Frequent full discharges should be avoided when possible. Instead, charge the battery more often or use a larger battery.
D4VE
PostPosted: Mon May 19, 2008 1:57 pm    Post subject: Reply with quote
Ok I stand corrected on both those points about later battery technology, thanks Oldboy Smile
iPhone4 IOS 4.3.3
22.055 (29 May 24)
