safire Occasional Visitor
Posted: Mon May 12, 2008 10:13 pm Post subject: 720 help please |
Proud owner of a brand new 720go T, to replace my aging Garmin. When connecting to PC, explorer comes up and can see the SD card, but TT Home says no TT device found. If I connect my PDA with TT Nav 6 on, it finds it straight away. Any help gratefully received, as I need this unit ASAP.
Cheers,
Steve
Sorry, just downloaded from site, and it works. Must be a problem with the CD |
DennisN Tired Old Man
Posted: Mon May 12, 2008 10:33 pm Post subject: |
First job is to do a backup using Windows Explorer, right NOW - copy everything into a backup directory on your PC (e.g. GO720Backup2008-05-12) and next time have another dated name for the backup and so on.
Now, have you REALLY got an SD card in there? They don't come with one fitted (but they DO have a dinky little false bit of plastic - can't think why!). So usually the "SD card" it's seeing is the internal memory.
So give us something more to go on please, telling us exactly what you've done and how.
Normally, if you install TT Home, it will start up automatically when you connect your GO to the PC - when you connect and switch on the GO, it asks if you want to connect to Computer and you tap YES. Window comes up on PC saying what do you want to do with Drive F (or whatever drive) and on mine, at the same time, Home fires up. So fire up Home. Then you will need to log in if you want to do anything much. The GO has to have its own unique email address and password and you also need the same details setting up as an account with TomTom - not the same as for TT Nav (if you've got a TT account for that).
No more for now until you come back with some more info. One VERY important thing when you do get it seen by Home - you MUST disconnect properly - click Device, Disconnect, then bottom right, click OK, BUT DO NOT disconnect at that stage. The Go will reboot and ask again if you want to connect to Computer, tap NO and when it then shows the map, you can safely disconnect. REMEMBER THIS DISCONNECT PROCEDURE.
Edit - GRRR - I see you didn't wait for advice _________________ Dennis
Two of them are obesiting!! |
dhn Frequent Visitor
Joined: Oct 08, 2007 Posts: 2544 Location: Toronto CANADA
Posted: Mon May 12, 2008 11:00 pm Post subject: |
Dennis, you should make your post into a 'sticky'. Well detailed! |
Posted: Mon May 12, 2008 11:12 pm Post subject: |
dhn wrote: | Dennis, you should make your post into a 'sticky'. Well detailed! | Sticky enough already - I hate to think what the temperature is in this back bedroom computer room full of computer, printers, fridge and stuff all pushing out therms! _________________ Dennis
Anita Pocket GPS Moderator
Joined: Mar 15, 2006 Posts: 3219 Location: Windlesham, Surrey
Posted: Tue May 13, 2008 2:44 pm Post subject: |
DennisN wrote: | Now, have you REALLY got an SD card in there? They don't come with one fitted (but they DO have a dinky little false bit of plastic - can't think why!) |
I assumed it was to keep dirt out of the slot! _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21 |
Posted: Tue May 13, 2008 2:54 pm Post subject: |
Some 720's (not mine) apparently came with a sticker covering the slot saying something like 'no sd card needed'. |
Posted: Tue May 13, 2008 7:23 pm Post subject: |
Anita wrote: | DennisN wrote: | Now, have you REALLY got an SD card in there? They don't come with one fitted (but they DO have a dinky little false bit of plastic - can't think why!) | I assumed it was to keep dirt out of the slot! | Now there speaks someone with a broken computer!! _________________ Dennis
